I dont have skype, but I suppose thats as easy as a download and another new password to remember
Im out on buisnes anyways.
I understand the XGATE not being up and running yet, so what pins are available for the current release? I guess if I had the code loaded into the tuning program, I would be able to tell for myself. Im still working on figuring that part out.
Maybe I should make this more simple. The only critical pins I need are the pins for ignition A,B, and C for wasted spark and two pins for my two banks of injectors. A normal MS install will not have more than that anyways, and the rest of the pins will be available on the header.
Regarding the 1k current limiting resistors, all of the circuits attached to the DIP40 do have this at a minimum and any add on card/circuit could deal with it there. Is there any reason I should do this on the CPU card?
Thank you both for your help!
