Hi all,
I'm working on CAN bus to add this mod to FreeEMS.
See all parameters without PC is necessary for me and I want discover CAN bus
I'm newbie in electronics so certainly a lot of errors but you're here
My work on github : https://github.com/flat4power/FreeEMS-CAN
You can help me with your ideas.
I'm French, I have a bad english, so be cool with me lol.
I don't know how organize this job on forum
Matthieu
CAN bus
- flat4power
Re: CAN bus
viewtopic.php?f=42&t=1896&start=0
I haven't finished or tested this code. Some of it might work though if you name everything the same in Fred's 9S12XDP512.h file.
https://github.com/pjohns30/FreeEMS-project-s-
What are you trying to use the CAN bus for?
:-p
- flat4power
Re: CAN bus
I want develop a module wich can be able to read over CAN.
9S12XDP512 had CAN possibility so it can be possible to communicate with the FreeEMS over CAN
I know that is possible with a PC over USB but I love all in one module
So with a CAN module all can be possible without a PC and it can control other things and other sensor of the vehicule
Firstly a want create a little module connect on computer and sending CAN information ( the freeEMS role of 9S12XDP512)
And secondly or in parallel working on a CAN module taht can receive the informations and display them on a screen
Lastly this CAN module should be able to change parameter of freeEMS and log on a SD card
I don't know if all is comprehensive or if I have some error on my english
Re: CAN bus
Some advice: Stop worrying about your English, it's good enough, and when it's not, we can ask. If you can't stop worrying, put something in your signature instead of repeating it all the time :-)
- flat4power
Re: CAN bus
ok I will stop repeat myself about my english
- ToxicGumbo
Re: CAN bus
Votre Anglais est tres bon. Mon Francais est tres mal. So let's make a deal: I won't butcher your language if you visit the following thread and continue discussing CAN.flat4power wrote:ok I will stop repeat myself about my english
http://forum.diyefi.org/viewtopic.php?f=42&t=1896&hilit=can
-Jeff
Re: CAN bus
LOL
- flat4power
Re: CAN bus
:p
