Page 1 of 3
Max Square Wave Latency
Posted: Mon Mar 26, 2012 4:13 pm
I just checked the entire code base over looking for
issue 499 only to find that the max9924 circuit on my PumaS1 introduces a constant 0.11ms of delay into the input, and thus the output, if you sample the input before the MAX chips...
I'm wondering if this is normal or if there is a problem with the Puma and if there is any way to reduce it to near zero. If not we'll have to add a hardware latency setting into the code soon. I was planning to eventually anyway, but I don't like the idea of needing that much of one by default.
I guess we'd really need three:
- Input latency
- Injector output latency
- Ignition output latency
All should be margin-of-error small, but right now the first one is fairly big for me.
Re: Max Square Wave Latency
Posted: Tue Mar 27, 2012 3:04 am
by DeuceEFI
Here are the results of my testing with the 1nF capacitor between the input resistors and without the capacitor.
Posted: Sat Mar 31, 2012 3:43 pm
by TonyS
Hey Andy (or Fred),
Fred stated in his software diary thread that issue 499 is now fixed.
Do the files you attached (which I don't know how to read) show that the delay was caused by the value of cap? Thanks, Huff
Posted: Sat Mar 31, 2012 6:40 pm
It seems to have an effect. I wonder if using a stiffer input resistor would be wise too. maybe 1k + no cap. Hard to say. This testing is far from complete.
Posted: Fri May 11, 2012 11:44 am
by MotoFab
Last night I chatted with DeuceEFI about this issue. On the Max9926 part, the 1nF cap across the inputs pins can be removed. The 9926 will operate just fine.
The other possibility is to feed the Hall Effect signal into the negative input pins (IN1- and IN2-), and let IN1+ and IN2+ float. Also no capacitor. In this configuration the output signal is inverted.
Posted: Fri May 11, 2012 5:00 pm
MotoFab wrote:Last night I chatted with DeuceEFI about this issue. On the Max9926 part, the 1nF cap across the inputs pins can be removed. The 9926 will operate just fine.
Actually, this is
not true. Andy showed a reduction to around 40% latency over the stock configuration which is still WAY too much.
This seems entirely pointless, and would render the output signal incompatible.
What may work is holding the negative line at 2.5V, though.
Posted: Sun May 13, 2012 5:01 pm
by TonyS
Hi Fred,
Can you detail your experimental setup a bit?
I am curious as to the details in determining how the 110us delay measurement was derived.
Does the Fredstim generate two, out of phase bi-polar signals with the 0V point being the time reference for your measurement?
Maybe you could also use the "Hall" configuration (0 - 5V square wave on + input and floating - input) to confirm latency.
Thanks,
Huff
Posted: Sun May 13, 2012 7:20 pm
Huff, the fredstim is a straight 0-5V "hall" signal, and at the time, I had a floating -ve lead and the cap installed. Andy tried without the cap and halved my latency. I came across it while testing firmware and thought i had a code/math issue. I checked and double checked every single line of code before clicking, realising, and checking the hw. I've not done any experiments or checks, however I may do some "any day now" as I have the required equipment to do that.
Posted: Sat Jun 09, 2012 3:06 am
Bump :-)
Posted: Wed Oct 03, 2012 12:17 pm
by Dan
Bump!
Can I do anything to help here?
