A programmable fan controller would be the simple way of resolving the problem, but where is the fun in that. Would much rather build something
Designing a uC that will adjust the fan speen using PWM and speed up when the AC is on. It will also provide CTS readings to FreeEMS and my dash as I only want to have one CTS in the engine bay and sharing sensors does not work well I am told. Found a digital pot that will do this nicely.
Despite trying to learn as much about FET's from google, I have questions on how to use this part
1) How far away can the flyback diode be from the fan? Everywhere says as close as possible to the motor, would 30 cm be to far?
2) From what I have read a flyback diode should be fast recovery, same current as the motor or more (20A) and support high reverse voltage, so would this diode work?
http://www.vishay.com/docs/94167/94167.pdf
3) What should the value of RG (gate resistance) be? From what I have read there should be a graph on the data sheet that explains this, I dont understand which on it is. My Vin will be 5V TTL from a uC.
4) Page 9 figure 5 shows an 85 ohm resistor on the source pin, why?
