USB interface
Posted: Thu Apr 03, 2008 8:32 pm
My first goal as a contributor will be to make usb work!! Or at least try!!!
Admin wrote:Another alternative for usb <> uart interface doing away with the rs232 physical transfer layer :
http://www.ftdichip.com/Products/Evalua ... MM232R.htm
http://apple.clickandbuild.com/cnb/shop ... tle=MM232R
...and EVEN smaller :
http://www.ftdichip.com/Products/Evalua ... UB232R.htm
http://apple.clickandbuild.com/cnb/shop ... tle=UB232R
On another note, this board has a usb host controller with transparent fat support on it! that means super easy datalogging to a usb hard drive (flash or full on big disk) :
http://www.vinculum.com/prd_vnc1l.html
http://www.saelig.com/miva/merchant.mvc ... Code=UI1E3
It's cheap enough, and should be dead simple to write an interface for. It should also leave you with virtually unlimited datalogging for continuous runs on track, or long drives etc etc etc.
Pretty cool little device really.
Admin.
