Grounds / ground planes
Posted: Sun Jul 24, 2011 2:49 am
So I just read yet another article that tells me we are doing this grounding thing all wrong. So I figured I'd post about it.
Does anyone have an article or something that notes we do in fact need multiple ground planes? Right now, I see our needs as power, and non-power.
As noted here http://opencircuits.com/Printed_Circuit_Boards analog and digital grounds should all converge at one point of the board. This is a close correlation of the NFPA70, which is why all house and branch circuits in the US are required to converge to one ground reference.
As noted in Circuitcellar mag 253 article "RF and High-Speed PCBs" by Robert Lacoste, that above reference is wrong in suggesting splitting of the ground planes. He claims that for EMC purposes/signal integrity issues, you want one ground plane and you steer your currents not physical, but electrically. Basically, the ground currents will follow the trace on the other layer. He claims if you split the grounds into planes, you will likely force the ground current to flow in a path that isn't the shortest possible path. Which will act like antenna, coupling energy where you don't want it. If done correctly, you can split your ground currents, while keeping one copper plane. He agrees there should be one ground wire returning to the supply.
I feel these articles don't fully apply here, as we have power, digital, and analog grounds. The power signals need to be on their own, as the voltage drops will cause signal integrity issues. So I feel we do need at least two grounds, but I can't seem to find an article that claims we need any more.
I guess I can also see the need for the infamous Guard Ring as discussed here. http://www.ce-mag.com/ce-mag.com/archiv ... E_028.html or the infamous safety ground, for protection against hazardous voltages. So I can see a need for A third ground wire, however with a metalic case, that's screwed to the sheet metal of a vehicle, which is then grounded, I can see how we won't need that. Any how, I don't think the layout folks here are concerned with EMC, and our electrical energy potentials aren't typically life threatening. So this third isn't really that important.
I see PUMA has a power ground, and other ground. However it does have semi split planes on the other ground side of things. So far I see PUMA as having the most reference documents to back it's design theory.
So does anyone have an article or something that notes we do in fact need multiple ground planes?
