Introduce to my Citroen ZX, engine, stock ECU, schema
HotCat
Post by HotCat »
My Chinese version Citroen ZX, 8 valve 1.6 L gasoline
Under my engine hood
VR sensor
Fly wheel
MAP
16 Ohm low impedance injector
TPS
IAT
Stock ECU, Bosch MP 5.2
Main controller, only 8 bit
back
Lowside switch chip
It's usage
Ignition transistor
Ignition output layout
The attachments is the external schema of my stock ECU, my objective is to tailor FreeEMS to compatible with the stock socket. There's a high resolution version uploaded on sendspace.
http://www.sendspace.com/file/6icv99
My tailoring work on puma board was allmost completed but not yet doing the layout. I don't know how to use github to fork the main trunk, anyone can provide a tutorial? or I'll upload my whole working directory on sendspace latter on
Bosch MP 5.2 schema
Bosch MP 5.2 schema
Re: Introduce to my Citroen ZX, engine, stock ECU, schema
Cool! :-)
nitrousnrg
Post by nitrousnrg »
Nice one!
Marcos
Spudmn
Post by Spudmn »
Very Cool.
Welcome on board HotCat.
BenFenner
Post by BenFenner »
16 Ohms sounds like high impedance to me?
BenFenner wrote:16 Ohms sounds like high impedance to me?
Typo from 1.6? Otherwise, yes, you're right. Good spotting.
HotCat
Post by HotCat »
Yeah, It's my mistake. High impedance means I don't need chip 1949 and darlington NPN to drive my injector. I've tested my injector, the saturation current is only 1A. All I need is a MOSEFT which can interface to I/O pin directly
HotCat, be careful, most normal MOSFET can't be reliably driven with the tiny current the cpu can provide. For ordinary ones, you need a driver chip. Look for logic level FETs such as the VNP10N07 or similar. Don't use PIP3104, they're junk, I found out the hard way...
