- 2 x 50 pin DIL sockets
- 1 x XOR logic chip (4 channels)
- 1 x LDO 5v regulator with 500mA Minimum
- 1 x 10uF tant or electro
- 1 x 22uF tant or electro
- several 0.1uF ceramics
- several 1.6k 1/4w resistors 1% tolerance
- several 1k 1/4w resistors 1% tolerance
- several 330ohm 1/4w resistors 1% tolerance
- 1 x map sensor
- power supply construction is pretty obvious, generate clean 5v from raw power and supply to TA card via fly lead
- leave the DIL 50 poewr and ground leads disconnected to avoid loops
- connect T0 to one output channel of the XOR via a 1.6k resistor
- connect the input of the same XOR channel to a the hall input wire from the dizzy
- connect a 1k resistor from that same input to 5v
- configure that XOR to be inverting, 5v on input = 0v on output and vice versa
- connect T2 to one input channel of the XOR via a 1.6k resistor
- connect the output of the same XOR channel to a 330ohm resistor, and off to the ignitor
- configure that XOR to be non inverting, 5v on cpu = 5v on output
- filter and condition the map sensor and power for it
This car needs to stay on the road with FreeEMS wired in, somehow.
