As in here, I'm not seeing it the way you described. I called it "U1A" and "U1B" and everything carried through fine - I hooked up both power pins, and everything just worked when I brought it into layout?
Good enough for OEM, good enough for usjharvey wrote:This circuit is what is used by an OEM. It filters and adds some hysteresis. The hysteresis could easily be done with some form of a Schmitt trigger, but then you'd also have to filter out some noise junk. The pro's of this circuit are that you can adjust the filter and hysteresis, where other circuits are harder to control. I'm sure it could be done several different ways, this one has some field testing, so it got included.
Hmmm....jharvey wrote:So I made a symbol for the XOR and the nets work just fine now. Resolve they way they should ect. Also I corrected the wrong connection to the opamp, and I'm making progress again.
Looks like after the three general FET circuits, I'm really forced to either copy the ignition / injection drivers, or move the RPM circuit on the board. That's going to be a tough one, I think the caps are to tall, and I'd rather not put those caps on the other side of the PCB if I can help it.
Perhaps the caps can go on the bottom side bent over, Hmmm, how to fit it.
I get the same. I've been ignoring it, but I believe the way to fix it has something to do with the "power flag" power port. I took it as an error that didn't effect the traces and nets, so I blazed a trail.8InchesFlacid wrote:Quick question: It seems like each of the power nets (+12, +5, GND) in my board have ONE error that says power pin undriven
I feel the same, I feel they didn't work because of a lack of understanding on my part. I also feel like making the symbol that doesn't use power ports is the easy way out. I would like to learn how to use them correctly, but also I want to keep moving forward with the layout.8InchesFlacid wrote:1) What did you have to generate a part for? I'm still trying to find a nice way to do this, I want a 50 pin header and it's driving me batty - but more to the point I wonder why the XOR's you already used didn't work.
I know some wouldn't be a problem, they could probably come as 0805, and solder right across the thru holes. The 33uF might be a different story. I'd have to go look that one up.8InchesFlacid wrote:2) I know people will yell, but could you get a surface mount cap, to save on vertical space? How much capcitor do they need?
