I did not read through the whole thread before, Fred just asked that I posted my opinion on this after we had some discussion on flyback suppression, which I did.Delta wrote:My design does all of this and only requires one output pin - did you read through the whole thread???
No, your design doesn't do all of this. It would dissipate more power during the current limiting period than the design I described earlier but like I've said, there are compromises to be made.
Care to run another simulation? I'd be interested in seeing the gate, source and drain voltages of M2 related to ground, also the voltage at C1.
You state that a comparator cannot operate at part-voltage and only latched to a rail. I must say I have observed otherwise, the comparator is really just a high gain amplifier and there is a sweet spot you can hold it at. However the positive feedback should help it oscillate.
Now, it's a clever approach to current limiting but I'm not convinced the flyback current won't burn it up.
