PCB layout - JHarvey
Re: PCB layout
w00t!
Re: PCB layout
I've found a little more about the colored PCB's.
copper clad translucent PCB found here
http://www.mgchemicals.com/products/500 ... html#specs
pre-etched / drilled blue PCB found here
http://export.farnell.com/jsp/search/br ... tid=223338
If the link to Farnell doesn't work search "blue epoxy glass" and it pops right up.
However I still haven't found a fab house that will provided colored etched boards.
GrowlingandBiffo
Re: PCB layout
How many do you want?However I still haven't found a fab house that will provided colored etched boards.
Is that the same as coloured?
Re: PCB layout
I think the first batch should be something like 5, once we get it and do some basic testing like are the traces big enough, did the vias work, solder mask worked, ect, then we can get more, but probably best to keep the first batch qty low.
Re: PCB layout
The colour of the PCB is that of the solder mask. Is that what you mean? Black, purple, blue, yellow, green and white, maybe others too, not sure... Then pick the overlay colour.
With the first batch, since the tooling costs are high and each PCB is cheap, order as many as there are takers up front, and then maybe half of them will get built, and maybe half of the built ones will get installed. Some that get built but not installed will do time on a test bench.
Re: PCB layout
I agree with Brian on this. I think the moral of the story is to think it through really thoroughly and make it really good right up front. That way it's not a bad thing for 10 - 30 people to get them in the first place.#
Additionally, those stats are probably right. EG, I won't be building mine up front, and if there are issues, maybe ever. I'm just in to bolster numbers as I'm using the toyota hardware for testing for the time being.
Re: PCB layout
I'll post about the group by in the purchase thread.
About color, you can have colored FR4, and colored solder mask. Many vendors offer the FR4 in green, whitish, and black. Then a variety of solder mask colors. I think that freeEMS might be show cased, a bit more then many other EMS's. I know I will be showing it off, and because of that, I want to put some extra effort into the look an feel.
Any how, I'll keep persuing my dream of a translucent FR4, because I'm not that concerned with the price. However, I also don't know what the price is yet, so that might change once I find a supplier. If some one esle starts a buy with normal board, I'll likely jump aboard, so don't hesitate if you're thinking we should order boards.
davebmw
Re: PCB layout
Hi All!
Is there a table somewhere that indicates what cpu pins perform what function? I am at the point where I need to route the CPU to the outside world.
Re: PCB layout
There is, in the docs directory of the code release, BUT, it's STILL subject to change at least for a few weeks more. I wouldn't be in too much of a rush though, the source has more or less been stagnant for a month, so it WILL be longer before we get a working system...davebmw wrote:Is there a table somewhere that indicates what cpu pins perform what function? I am at the point where I need to route the CPU to the outside world.
Re: PCB layout
Awesome. I'm curious what your putting down. Are you doing a spin of the one I drafted, or are you doing an addon of some sort? Perhaps a connector card?davebmw wrote:Is there a table somewhere that indicates what cpu pins perform what function? I am at the point where I need to route the CPU to the outside world.
I'd be happy to review and comment if you post something I can check out.
