Hello everyone that just ordered a Puma board and are planning to run FreeEMS on it (or not)!
Sean and I need to know *exactly* what your setups consist of so we can focus our work to the benefit of the most people the soonest. Please post once (only) in this thread for each PCB/vehicle combo you plan to run. For example, if you ordered two boards and one is going on your wall as a souvenir and the other into your 1967 mustang, then one post will be short describing your wall, and the other will layout the details of your vehicle by quoting an earlier poster and using it as a template. If you have one board, and plan to trial it on more than one vehicle, perhaps daily and project car (that doesn't need one full time) then post twice, once for each. If you've got one for the hell of it, and aren't sure what it's going on just yet, post so. You can always edit your posts later, the main thing is to get a complete picture of what is happening with these cards and what code is required to make that happen. If you didn't order a card, do NOT post! Marcos, I want 4 or 5 posts from you for your 4 or 5 boards! Ditto you Abe! Everyone else has an easier job ;-)
I'll post my own setup as an example now. Please follow suit. If you don't post, I will dog you until you do :-)
Usernames
5 Marcos
5 Abe
2 Fred
2 Seank
1 Craig
1 Joseph Davis
1 johntramp
1 Quan-Time
2 flyrdm
1 em_knaps
1 mops
1 yoshifab/sdturbo
1 Nick S
1 phr34kr
2 Karri
1 jbelanger
1 dirtydsi
1 colza
1 Motofab
1 Gimpy
1 gearhead
1 mtxman
2 cavehamster
1 f1erce
Comments: viewtopic.php?f=8&t=989
Puma Owners Usage Details
Re: Puma Owners Usage Details
Please quote this post, remove the quote tags, edit to reflect your setup and hit submit!
General
Make: ford/gm/mazda/toyota/nissan/etc
Model: Example
Engine Code: ?
Displacement: litres please!
Cylinder count: 1 - 12
Cylinder config: v8/boxer/v twin oddfire/I4/I6/I5/v6/etc
Compression level: X:1
Induction style: ITBs/Single throttle/?
Strokes: 2/4/Rotary
Fuel setup
Injection control: Yes/No
Injector config: port/staged/throttlebody/siamese
Injector count: 1 - 24
Injector flow: cc/min or lb/hr
Ignition Setup
Ignition control: Yes/No
Style: Distributor/Wasted Spark/COP
Config: normal/rotary trailing/oddfire/etc/dodgy saab
Power adders
Nitrous: No/Yes type of control?
Boost type and level: none / turbo X psi / super X psi / hybrid or twin X psi
Boost control desired: No/Yes
Accessories
Idle control: None / 2 pin PWM / 3 pin PWM / Stepper / Idle up or fast idle solenoid
aircon input: no/yes
knock sensing: no/yes
pwm fuel pump: no/yes
anything else: ?
Sensors
Cam and crank wheel style: None/36-1/60-2/DSM 4+2 /NipponDenso 24+2/single short pulse on cam/180 degree pulse on cam/pulse per cylinder/etc
Cam pattern: ditto/details
Crank pattern: ditto/details
Variable Valve Timing: no/yes details
Air measurement: TPS/MAP/MAF with or without baro?
Wideband: No/Yes - style of output signal
Misc Notes
Nothing/Anything unique or weird or special about your setup that we even so much as MIGHT need to know about.
All setups will require a basic compliment of analogue sensors. IAT/MAT/both (Inlet/Manifold Air Temperature) and CHT (Coolant/Head Temperature) and preferably a TPS
Replace any of the above that yes/no isn't suitable for with N/A if Not Applicable! Don't remove lines.
General
Model: Example
Engine Code: ?
Strokes: 2/4/Rotary
Fuel setup
Ignition Setup
Power adders
Accessories
anything else: ?
Sensors
Misc Notes
General
Make: Mazda
Model: B2000 - 1989
Engine Code: FE-DOHC
Displacement: 2.0 litres
Cylinder count: 4
Cylinder config: I4
Compression level: 10:1
Induction style: Single throttle
Strokes: 4
Fuel setup
Injector config: Sequential port injection with single rail and bank
Injector count: 4
Injector flow: rx7 550cc tested as 650cc
Ignition Setup
Style: COP/CNP
Config: normal
Power adders
Nitrous: No
Boost type and level: turbo 17.5 psi
Boost control desired: Yes
Accessories
Idle control: None
aircon input: no
knock sensing: yes
pwm fuel pump: yes
anything else: no
Sensors
Cam and crank wheel style: 36-1 + single cam pulse OR 4 pulses + single cam pulse
Cam pattern: ditto
Air measurement: MAP with baro if possible
Wideband: Yes - linear 0 - 5v
Misc Notes
Nothing
Make: Mazda
Model: B2000 - 1989
Cylinder count: 4
Cylinder config: I4
Strokes: 4
Fuel setup
Injector count: 4
Ignition Setup
Style: COP/CNP
Config: normal
Power adders
Nitrous: No
Accessories
Idle control: None
aircon input: no
knock sensing: yes
pwm fuel pump: yes
anything else: no
Sensors
Cam pattern: ditto
Misc Notes
Nothing
Second board is homeless for now, just like me!
Will fill out details when I have them.
General
Make: Subaru derivative
Model: Lancair IVP aircraft
Engine Code: EZ30R
Displacement: 3.0L
Cylinder count: 6
Cylinder config: boxer
Compression level: 10.7:1 stock, 8.5:1 as built
Strokes: 4
Fuel setup
Injector count: 6
Injector flow: 650 cc/min
Ignition Setup
Style: COP
Config: normal
Power adders
Nitrous: No
Boost type and level: single & twin 2.0 bar MAP
Accessories
Idle control: Stepper
aircon input: no
knock sensing: yes
pwm fuel pump: no (but would be nice to have capability)
anything else: Would like
Sensors
Cam and crank wheel style: 36-2-2-2
Cam pattern: 3 pulses per cam rev
Crank pattern: (36-2-2-2 wheel)
Air measurement: MAP w/ baro correction necessary
Wideband: Yes - 0-5V
Misc Notes
Would like the loss of crank sensor to go to wasted-spark as a limp-home mode.
This is a 400 HP aircraft. It is flying now with a commercial ECU.
Engine Code: EZ30R
Displacement: 3.0L
Cylinder count: 6
Strokes: 4
Fuel setup
Injector count: 6
Ignition Setup
Style: COP
Config: normal
Power adders
Nitrous: No
Accessories
aircon input: no
knock sensing: yes
Sensors
Misc Notes
General
Make: mazda
Model: miata
Engine Code: bp6something?
Displacement: 1.8
Cylinder count: 4
Cylinder config: I4
Compression level: 9:1
Induction style: OEM Single throttle
Strokes: 4
Fuel setup
Injector count: 4
Injector flow: 550 cc/min
Ignition Setup
Style: Wasted Spark - COP (bank fired)
Config: normal
Power adders
Nitrous: No
Boost type and level: turbo X 15-ish psi
Boost control desired: Yes!
Accessories
Idle control: 2 pin PWM (+fast idle solenoid if needed)
aircon input: "yes" (Big Fucking Stereo)
knock sensing: yes!!! (OEM sensor if possible, KnockSense output if not
pwm fuel pump: no (why?)
anything else: Would like more outputs!
Sensors
Cam and crank wheel style: Crappy OEM VR-translated-in-sensor to open collector
Cam pattern: 1 pulse odd cyl, doublett even cyl. Details available elsewhere
Crank pattern: 4 unevenly spaced
Variable Valve Timing: No
Air measurement: TPS,MAP with baro (if we can use it For Good)
Wideband: Yes - 0-5V, scalable (LC-1)
Misc Notes
No VVT on this one. The cam/crank sensors are a bit weird, but otherwise it's pretty plain-jane. Not sure if the knock circuit will work with this one.
Would love to read/log/react to low oil temps as well as water.
1200 watt amp in combination with fans and hvac system occasionally puts large load on engine, unexpectedly. Great test for idle code.
"Junk" motor I'm ready to see out.
Make: mazda
Model: miata
Displacement: 1.8
Cylinder count: 4
Cylinder config: I4
Strokes: 4
Fuel setup
Injector count: 4
Ignition Setup
Config: normal
Power adders
Nitrous: No
Accessories
Sensors
Misc Notes
(Yes, the same car, but a new motor after some bugs are worked out)
General
Make: mazda
Model: miata
Displacement: 1.85 (overbore)
Cylinder count: 4
Cylinder config: I4
Compression level: 8.2:1
Strokes: 4
Fuel setup
Injector config: port (MIGHT add secondary rail back in)
Injector count: 4 (8)
Injector flow: 550 cc/min (~250 (OEM) + 550/750, possibly two tank high octane setup)
Ignition Setup
Style: COP
Config: normal
Power adders
Nitrous: No
Boost type and level: turbo X 20-25 psi
Boost control desired: Yes, TPS dependant
Accessories
knock sensing: yes!!! (OEM sensor if possible, KnockSense output if not)
pwm fuel pump: no, possibly two channel?
Sensors
Cam and crank wheel style: Crappy OEM VR-translated-in-sensor to open collector - IF needed, ~16+ tooth crank wheel
Variable Valve Timing: YES
Air measurement: TPS,MAP with baro (if we can use it For Good).Someday dream of 1 MAF/cyl
Misc Notes
Biggie ported VVT on this one, higher revs. The cam/crank sensors are a bit weird, perhaps a solid crank sensor (start in bank fire for quick starts), keep OEM cam sensor? Would really like VVT support!
General
Make: mazda
Model: miata
Cylinder count: 4
Cylinder config: I4
Strokes: 4
Fuel setup
Ignition Setup
Style: COP
Config: normal
Power adders
Nitrous: No
Accessories
Sensors
Misc Notes
General
Make: Kawasaki
Model: KZ-1000 (1977)
Engine Code: ????
Displacement: ~1200? 1100?
Cylinder count: 4
Cylinder config: I4
Compression level: 7.x:1
Induction style: Single throttle? Undecided
Strokes: 4
Fuel setup
Injector config: undecided. Perhaps TPI?
Injector count: 4-or-less
Injector flow: total ~ 1500-2000 cc/min unless I run alch (~250 whp)
Ignition Setup
Style: Wasted Spark - COP or aftermarket coils (bank fired)
Config: normal
Power adders
Nitrous: No
Boost type and level: turbo X 15-ish psi current. ~20?
Boost control desired: Per gear is nice on bikes. Not sure I care.
Accessories
Idle control: fast idle solenoid if needed
aircon input: no
knock sensing: yes!!! Open to sensor make/model (though have spare Mazda units)
anything else: Just needs to run.
Sensors
Totally undecided here. I've got nothing. There's a crank tap. I can fab a 36-1 setup, or a hall set up really easy, used to have a powercommander style one till I put it on a mini for a race.
Cam and crank wheel style: undecided. Possibly crank only.
Cam pattern: undecided.
Crank pattern: undecided (none?)
Air measurement: likely MAP, easier. Could get a MAF?
Wideband: Yes - 0-5V, scalable (LC-1). No closed loop.
Misc Notes
This was a bike I'd run carburetter (and blew a few motors) while in my first years of college. Took it apart for a new carb and never finished it. Would like to see it running. Forged pistons, cent. assist clutch, but basically stock. I've had ignition on it (never got timing retard working on it. Go figure it blew up). The goal is to make it reliable and a simple 175+ whp. Not looking to win any records, just want to have it running. The alternative is to put the MS2 I will be exercising from the Mazda on here.
Make: Kawasaki
Engine Code: ????
Cylinder count: 4
Cylinder config: I4
Strokes: 4
Fuel setup
Ignition Setup
Config: normal
Power adders
Nitrous: No
Accessories
aircon input: no
Sensors
Misc Notes
General
Make: Suzuki
Model: TL1000R
Engine Code: ????
Displacement: 998? 996?
Cylinder count: 3
Cylinder config: 90* twin
Compression level: 9-10?:1
Induction style: OEM dual throttle
Strokes: 4
Fuel setup
Injector count: 4 I think
Injector flow: unknown cc/min. Might be symmetric.
Ignition Setup
Style: two coils?
Config: normal
Power adders
Nitrous: No
Boost type and level: Really would only do this to turbo it. Would start NA though.
Boost control desired: Yes, gear (+tps) dependent
Accessories
Idle control: I don't think so. Would love to add fast idle, perhaps with advance?
aircon input: no
knock sensing: Desired. Forget if OEM has one. Think not.
anything else: meh
Sensors
Cam and crank wheel style: OEM crank + cam
Cam pattern: don't remember
Crank pattern: don't remember
Variable Valve Timing: No*, does have a compression release setup OEM
Air measurement: TPS, MAFx2
Wideband: Yes - but no closed loop. Didn't have it OEM.
Misc Notes
This would be a fun little bike to just mess with. Needs some FI love. V-twin has great feel, only imagine it'd be better with a turbo. Might very well become the best sound in the world.
Make: Suzuki
Model: TL1000R
Engine Code: ????
Cylinder count: 3
Strokes: 4
Fuel setup
Ignition Setup
Style: two coils?
Config: normal
Power adders
Nitrous: No
Accessories
aircon input: no
anything else: meh
Sensors
Misc Notes
No intended vehicle yet, thinking about going to EFI in the Scimitar (3ltr ford Essex v6) but need to get the car finished first, unless i have a play with the spare engine I have in the garage
