View unanswered posts | View active topics It is currently Tue Mar 26, 2019 1:52 am
Reply to topic  [ 12 posts ]  Go to page 1, 2  Next
Bit fields and (very)short integers!
Why didn't someone tell me about these things?!?! I was reading someone elses firmware code last night (GPL) and saw this :
Code:
   struct s_flags
      unsigned inj_occurred   :1;
      unsigned cranking      :1;
      unsigned running      :1;
      unsigned asc         :1;
      unsigned roc_update      :1;
      unsigned iac_update      :1;
      unsigned iac_reset      :1;
      unsigned cts_update      :1;
And when used they look like this :
Code:
status.flags.inj_occurred = TRUE;
And this :
Code:
if (status.flags.inj_occurred){//Do work}
I'm currently ashamed of and embarrassed by my code. I'll be converting it to use these in the nearish future...
It's night and day better...
THANK YOU cpuTorture!!!
Tue Apr 20, 2010 12:11 am
Additionally, for shorter than one byte integers nested inside registers this is ideal. You can just use :2 instead and you've got yourself 0 - 3 or :3 for 0 - 7 etc!
Tue Apr 20, 2010 12:15 am
Sorry, I do remember bit fields from K&R.
You snooze, you lose!
Tue Apr 20, 2010 12:16 am
Profile YIM
I wonder if it's as fast though............... with bit fields inorder to "get" a bit from a byte it must do a bit-wise then use that value, not just use the value. What do you think ?
Tue Apr 20, 2010 12:18 am
Profile YIM
I think it's just going to mask it off as we do manually at the moment.
Each and every time I set a bit, I have to use or or and and a mask. It'll just be doing this behind the scenes. We can write some test code to try it out and compare the binary/assembly, but it'll probably be the same or better. Even if it's worse, it's going to clean up the code no end!
The code above runs on a 2mhz cpu... this guy cares about speed a LOT. So I doubt it's slow for that reason too!
I did try to search for boolean types early on, but I failed to find this, mostly because its not a boolean type, really.
I'm excited about doing the change :-)
Tue Apr 20, 2010 12:36 am
Sorry from your first post I thought you were using entire bytes for bits. I should have known better :)
Tue Apr 20, 2010 2:21 am
Profile YIM
I considered that early on too, but it was a factor of 8 too wasteful LOL :-)
Tue Apr 20, 2010 2:38 am
thats the beauty of bitfield .. you lean on the compiler to do all the masking/shifting for you .. but I think each has their place.
'old-school' firmware folks that I know hate them with a passion .. because they 'can't trust the compiler'. When I point out all their masking/shifting screwups, they get even madder .. because they have never been able to point back and show me where the compiler has ever screwed up on me.
I make personal exceptions for clarity, here's an example from some code i just did a couple of days ago. it's for some dead simple pin setup code. this is just for a couple of simple single bit fields in a register (which has more fields) but I want to keep the example short:
#define OUTPUT_BUFFER_ENABLE ( 1 << 10 )
#define OUTPUT_MODE ( 1 << 10 )
#define INPUT_BUFFER_ENABLE ( 1 << 9 )
#define INPUT_MODE ( 1 << 9 )
#define READBACK_ENABLE ( 1 << 9 )
I can construct things like:
func( GPIO | OUTPUT_MODE | READBACK_ENABLE ); // 'descriptive'
vs
func( GPIO | OUTPUT_BUFFER_ENABLE | INPUT_BUFFER_ENABLE ); // 'dry'
which mean the same thing ...
as an alternative, using the bitstruct way, ponder this ... how would you handle r-m-w operations atomically on a register when you had to setup multiple fields (i can give an example of how I would do it) ? sometimes the code gets a bit longer than you anticipated .. but its safer since the compiler is working for you.
I also have some other things I do for multi-bit fields to get some asserts() and 'contract-like' programming into my code .. which all compiles out w/NDEBUG like all of the other asserts.
you MAY also run into ordering issues if you use different compilers within the same platform - its considered a highly unportable construct to be using .. so do you trade the danger of shifting/masking across platforms or do you just change the ordering of your struct ?? tradeoffs everywhere in C.
did I go way off track on this ? tell me where to expand if you're interested. I can throw in some 'non-sensitive' real world current examples.
Tue Apr 20, 2010 4:07 am
Hmmmmmmmmmmmmmmmmm
Mask:
Code:
.LSM189:
   ldd   coreStatusA
   anda   #2
   andb   #0
   tbeq   d,.L74
Bitfield:
Code:
.LSM189:
   ldab   coreStatusA+1
   rolb
   ldab   #0
   rolb
   beq   .L74
I'm unsure about the number of bus cycles those intructions take, but assuming its 1 each or equal between the two, bitfields are slower and regardless they are definitely bigger :-/
Code:
fred@roadeee [07:39:54]:src$ l masks/firmware/
total 900
-rwxr-xr-x 1 fred fred 150742 2010-05-30 21:31 freeems-0.1.1-SNAPSHOT-LT1-360-8.s19
-rwxr-xr-x 1 fred fred 150622 2010-05-30 21:31 freeems-0.1.1-SNAPSHOT-MiataNB.s19
-rwxr-xr-x 1 fred fred 151860 2010-05-30 21:31 freeems-0.1.1-SNAPSHOT-MissingTeeth.s19
-rwxr-xr-x 1 fred fred 153666 2010-05-30 21:31 freeems-0.1.1-SNAPSHOT-NipponDenso.s19
-rwxr-xr-x 1 fred fred 152220 2010-05-30 21:31 freeems-0.1.1-SNAPSHOT-Simple.s19
-rwxr-xr-x 1 fred fred 150622 2010-05-30 21:31 freeems-0.1.1-SNAPSHOT-Subaru-36-2-2-2.s19
fred@roadeee [07:39:55]:src$ l bitfield/firmware/
total 900
-rwxr-xr-x 1 fred fred 150768 2010-05-30 21:09 freeems-0.1.1-SNAPSHOT-LT1-360-8.s19
-rwxr-xr-x 1 fred fred 150634 2010-05-30 21:09 freeems-0.1.1-SNAPSHOT-MiataNB.s19
-rwxr-xr-x 1 fred fred 151872 2010-05-30 21:09 freeems-0.1.1-SNAPSHOT-MissingTeeth.s19
-rwxr-xr-x 1 fred fred 153754 2010-05-30 21:09 freeems-0.1.1-SNAPSHOT-NipponDenso.s19
-rwxr-xr-x 1 fred fred 152232 2010-05-30 21:09 freeems-0.1.1-SNAPSHOT-Simple.s19
-rwxr-xr-x 1 fred fred 150634 2010-05-30 21:09 freeems-0.1.1-SNAPSHOT-Subaru-36-2-2-2.s19
Granted, not much, but still...
A bit disappointing :-/
Sun May 30, 2010 8:43 pm
Every single platform I've written to it always comes out bigger ... except for one .. if was on 8051. Mostly, I think its an optimization issue and the '51 compiler devs probably put the extra effort in to ensure it was still efficient.
I bet if you targeted a platform like ia32 .. someone has put the effort into the gcc optimizer.
Sun May 30, 2010 8:53 pm
Users browsing this forum: No registered users and 16 guests
