MotoFab wrote:Direct injection is at a pressure nearly high enough to vaporize the fuel through phase change across the nozzle. That's the only way it can work. Otherwise, there would be unburned fuel in the combustion chamber.
Don't forget water droplets are typically preferred for water injection. It's also common to add a soap like substance to change the properties of how the droplets change from drops to gas. That flash from liquid to vapor not only expands rapidly, increasing the pressure, it also takes a lot of energy, which helps keep the temperature down. A combustible flame front is very similar.
Droplets will help slow down the flame front, increasing the amount of time your above the flash point, increasing the chances you have an oxygen around to react with. Bettering your emissions, while giving you more power.
Generally you're looking for enough atomized gas to allow combustion, with the rest of the charge as droplets, that allow for a powerful burn. If you run 100% atomized gas, your flame front will propagate very rapidly increasing the chances of knock, forcing you to decrease your compression ratio. This decreases how much energy you can tap out of the burn. A slower flame front allows you to capture more energy. Kind of like how you typically see an increase in fuel economy with higher octane rated gas. It takes longer to burn, decreasing your chances of knock, as well you get more energy out of each cycle.
Manufactures often use different injectors and injector position to vary the ratio of droplets vs atomized gas. It's kind of an art figuring out how to load the charge you're looking for. Are you looking for pep, or smooth running.
As for a clean burn, that's a different story, where direct injection is king. GDI allows you to insulate the cylinder walls with a wall of unburnt air, decreasing the losses in your heat pump. Ultra lean mode allows for an option you simply can't really touch with fuel injection.
Some draw backs to GDI include a lack of trained mechanics, a lack of field testing / refinement, and different techniques for diagnosing problems. With fuel injection, you can diagnose most problems with a scope, however with GDI, it requires a completely different set of tools. Note I just compaired a tool, to a set of tools.
MotoFab wrote:We can talk about that "next to no X-Tau effects", but the motor is going to have the last word.
When shot directly into the cyl via open valve, there isn't much on the manifold walls to compensate for. Each charge is precisely tuned for each cycle.
