Page 1 of 3
Is anyone using a Windows IDE?
Posted: Fri Nov 21, 2008 11:57 am
by MotoFab
I saw a couple of old threads on developing EWS code in Windows. Is anyone using a good IDE and running a simulator, set up in windows, to develop EWS code for the S12X controller?
There were mentions of Eclipse with some collection or another of various plugins and compiler. Or, maybe the free version of CodeWarrior will continue to work with the code size for a while.
The ideal thing would be an easy to install and maintain IDE, with a simulator. This while I become familiar enough with C to make some worthwhile contribution.
btw Do I understand it right that this is your first C project too, Fred?
- Jim
Re: Is anyone using a Windows IDE?
Posted: Fri Nov 21, 2008 12:20 pm
MotoFab wrote:Or, maybe the free version of CodeWarrior will continue to work with the code size for a while.
We are nearly double that limit already... forget that ;-)
Just use eclipse, its cross platform.
Posted: Fri Nov 21, 2008 1:03 pm
by MotoFab
Fred wrote:We are nearly double that limit already... forget that
Oh, I thought the code was just now reaching 32K, or that was prolly the tables only then.
I was hoping there was someone here using either CodeWarrior or Eclipse to help with the initial project setup, and processor variable setup, inside the IDE.
- Jim
Posted: Fri Nov 21, 2008 1:23 pm
MotoFab wrote:I was hoping there was someone here using either CodeWarrior or Eclipse to help with the initial project setup, and processor variable setup, inside the IDE.
There is no setup to do. The IDE is acting as a glorified editor in the most part. To actually build the project you just need gnu make and other simple cli tools.
Just download it and get it more or less building first.
Posted: Fri Nov 21, 2008 1:48 pm
by MotoFab
Fred wrote:There is no setup to do. The IDE is acting as a glorified editor in the most part.
For me, those items you mention qualify as needing some help to setup. As I do not have any idea what the terms are, except that gnu sounds like something for Linux.
At this point, it is largely another language for me Fred. I was hoping to use a more 'fully managed' IDE like CodeWarrior. If I am to use Eclipse, which makes sense for an open source project, getting the application and project set up will require much hand-holding.
I'll download Eclipse and install it. eclipse-cpp-ganymede-SR1-win32.zip
- Jim
Posted: Fri Nov 21, 2008 2:22 pm
Posted: Fri Nov 21, 2008 2:31 pm
by MotoFab
Thanks, I'll have a look at the links. I have the latest Eclipse installed now, and I'm watching a couple of hours of video tutorials. I'll post up later tonight and we'll see about what's needed to do a build.
- Jim
Posted: Fri Nov 21, 2008 2:44 pm
Posted: Fri Nov 21, 2008 2:57 pm
by MotoFab
Right-o I'll install them and post up tonight.
- Jim
Posted: Fri Nov 21, 2008 7:32 pm
Change of tack.
The gcc package is correct, but the gnu stuff is not the best to use.
Also, the make that comes with gnuwin32 behaves slightly different to the linux one so a change of make file is required too.
it builds fine though
install these :
you can get gcc from where i said, but the other tools come from here :
http://gnuwin32.sourceforge.net/packages.html
make file attached, and will be in next release.
