Serial Communication Take 2
Re: Serial Communication Take 2
There are two header bit flags for acks.
One says "I'm present" and the other "I'm positive or negative", then there is the ack field itself.
If you used 125 last time you sent a request with ack, send 126 this time and you should get 126 back in your reply.
The serial docs are a little out of date, but this thread indicates my intention and what I coded tonight echoes that.
You'll receive a copy in the mail a little later, hopefully that will clear it up. I'll update the docs on the train tomorrow.
- sry_not4sale
Cool, I figured that - the doc just seemed confusing
If you can reword it, go ahead :-)
She Lives! :
Sent :
translation :
Received :
translation :
Sweet :-)
Sent :
0xAA, 0x01, 0x00, 0x00, 0x01, 0xCC
start, flags(is protocol packet), payload ID = 0x0000 (0), checksum, stop
\0xaa\0x11\0x00\0x01\0x00\0x14\0x00\0x00\0x11IFreeEMS Vanilla\0x00\0xce\0xcc
start, flags (is protocol packet, has length field), payload ID = 0x0001 (1), length = 0x0014 (20), payload = 0.0.17 "IFreeEMS Vanilla" null byte, checksum, stop
And there was much rejoicing.
LOL, wel, lets be honest, there wasn't much at all really ;-)
It does much more than just that now, but even though I didn't experience any, I know it's buggy... I've got a bit of work to do before I call it done but its pretty close ;-)
Obligatory screen shot :
![Image](http://i260.photobucket.com/albums/ii15/diyefi/freeems-firmware-design/firstTableSentBack.png)
Re worked and highly changed serial code finally works and works well.
It needs some polishing and it needs much testing (that's where you lot come in) but it's pretty much there!
https://sourceforge.net/project/showfil ... _id=639615
Core docs are here ^
Version specific are now with the firmware only.
I need to re-read this and update it, for now, bumping as a reminder. Many serial changes have been made, all good. There is still multip interface stuff to do, but it's unimportant right now. Most of the functionality we have now will remain as it is. The documents are up to date, see docs/ and docs/interface for more info on what is currently implemented. If you find some behaviour that isn't documented then please file a bug report, either the docs or code will be fixed, or you will be proved wrong.
EDIT: Wow, it was old...
Some more proposed changes to the protocol and discussion around that are available here: http://issues.freeems.org/view.php?id=355
