Pretty cool trace :-)
Where is the practical benefit in this? Am I blind to not see it, or is there none there? I know gearhead and myself both think the model based stuff is largely a "for the fun of doing it" sort of thing rather than something that will deliver a real world performance benefit.jbelanger wrote:Also, I think that the "correct" sampled value will become important when we start talking about model-based fueling.
Yeah, I'd expect that as any normal map sensor is like that. As for the rest, no idea.jharvey wrote:Do you expect a MAP of 1V to equal X PSI (bar, ect)?
The curve isn't an air flow curve though, it's a pressure curve. When using VE and pressure to estimate your cylinder filling what you really want is the pressure found in the cyilnder after the valve closes. The manifold pressure is an approximation to that because cylinder filling will always be close to the same as manifold pressure. Thus what you probably want for VE accuracy reasons is the highest pressure seen which correlates roughly to when the valve closed and therefore the pressure of the cylinder.I picture the air flow is probably porpotiant to the average curve.
Nope, I stole the image outright :-)I'd claim average at about 2.1V. Can you do another at say 1K RPM, 2K RPM, ect?
