Flash Cycle Tracking
SleepyKeys
Post by SleepyKeys »
I have an idea. What do you guys think about adding a log/counter to the tuner program so that it keeps track of how many times a flash address has been burned?
We could also have an internal counter as well, so that it can send logs to the tuner program the next time it's connected? If the firmware has the ability to burn itself.
Or am I way off base ?
-sean
You snooze, you lose!
jharvey
1N4001 - Signed up
Re: Flash Cycle Tracking
Post by jharvey »
Sounds like a good idea to me. Although perhaps Fred is right and we should focus on the basics at first.
Is that an idea your able to write code for?
SleepyKeys
jharvey wrote:Sounds like a good idea to me. Although perhaps Fred is right and we should focus on the basics at first.
He is right, no rush, just an idea that came to mind.
Probably, its actually pretty simple.
Fantastic idea :-)
We can just dedicate 16 bits or 32 bits to the end of each block to record the burn count in. Of course updating firmware will blow it away, so you would want to have some mechanism to save it outside the device before a firmware upgrade, or perhaps include that as a build requirement when you build a new firmware :
#define currentBurnCount 3456 // please set this number to one higher than your current count such that the firmware burn is included, thanks.
etc.
Rather than do this in the flash itself, perhaps we should keep a small datamap with an unsigned long per 1k block in the eeprom? The eeprom is fine with being rewritten regularly and that way we keep full flash space available (which is fairly critical for the tables for example).
I guess I just thought up another block of work for Sean ;-)
(ie create some eeprom burning functions, i'll throw up a task for it now)
