Large table usage suggestion free for all!!
Like it says, make all your suggestions, I'll add them to a list up the top here and try to keep quiet :-)
All tables referenced by RPM versus Load except where noted.
  • VE tables
    • 2 banks of tables for table/fuel switching (any reason to have 3+?)
    • 2 tables per bank for V/boxer/twin/siamese/etc use (other uses needing more than 2?)
  • Ignition advance
  • Fuel advance * 4 (v/boxer/twin/sia/etc * 2 X staged injection * 2)
  • Lambda * 2 (table/fuel sw)
  • Explicit 3d dwell table * 1 (RPM versus Voltage)
Fine print (obscured because it shouldn't affect your brain storming) :
Limitations of space (which you don't really need to know about) :
32 - 8 = 24
24 / 1 = 24 (duh) conventional tables able to be paged through 6 window slots 4 at a time
However, if we go to a points based system later, it might be better to use more space for the structure at which point it could become 12 or 6 big tables. Of course, not all of them NEED to be that type (only advance and VE really)
Go nuts!
SleepyKeys
Re: Large table usage suggestion free for all!!
Post by SleepyKeys »
Injector opentime offset vs voltage
You snooze, you lose!
oxygen level adjustment. So if you know you're in an area with 20% O2, vs say Japan with less then 15%.
I should clarify :
By large table I mean full size primarily with RPM and Load as indices. IE, things that require mapping in 3d with respect to detailed operating conditions. Such an oxygen percentage would be a fixed trim over all values and the injector dead time is 2d defined by voltage only.
If I said large subwoofer I wouldn't mean 10" ;-) Large turbo to me is HX52, not HE351 etc :-)
