Idle entry conditions
Posted: Sat Jun 21, 2014 11:45 am
Wich conditions have to exist that the EMS enters idle mode ?
So we got 3 reasonable values the EMS needs to determine a idle condition
- MAP
- RPM
- TPS
But what if the ambient temperature is -10°C and the engine needs to idle at 1200rpm and 45kpa ?
So should MAP and RPM conditions for idle be based on a curve ?
Maybe something like this
A MAP_idle_condition curve could look like:
MAP | 45 45 40 40 35 35 | kPa
CLT | -15 -5 10 40 60 90 | °C
A RPM_idle_condition curve could look like:
RPM | 1300 1100 1000 950 900 900 | rpm
CLT | _-15__ -5 __ 10__40__60__ 90_ | °C
- MAP
- RPM
- TPS
if (MAP < 40 && RPM < 1000 && TPS < 5)
set engine idle ;
if (MAP < MAP_idle_condition && RPM < RPM_idle_condition && TPS < 5)
set engine idle ;
} MAP | 45 45 40 40 35 35 | kPa
