View unanswered posts | View active topics It is currently Mon Sep 21, 2020 1:02 am
Reply to topic  [ 4 posts ]
start-up
Hi
I'm using google translator - sorry something than be understood.
Possessed ms3 but struggling burned and so car is 1year.
He wanted me to run it on your solution, but I have a few questions.
1 Is it possible to run code on the processor mc9s12xep100? - Because I have the 4 pieces clean.
2 Is there a change maps as in the MS table switching.
3 Was that the possibility of changes in the processor output coil?
Mon Apr 14, 2014 7:15 pm
No problem! :-)
You had a difficult time with ms3 and eventually burned it out, and the car has been off the road for 1 year as a result? If so, gutted.
Who is "he"? Or did you mean "I want to run it on..."? :-)
Not at the moment, sorry, no. It wouldn't be a huge amount of work, but if you're asking, then it's likely not for you to do.
This is very easy to do, but what is your purpose for switching tables?
I don't understand this at all. Reword in your own language (which is what?) and re-translate for us. :-)
Mon Apr 14, 2014 7:52 pm
I had a car fired on ms3 but burned processor.
Changing the fuel and ignition maps for LPG
As someone hovers me how to move the coil from the PT to the PA will do it myself.
Mon Apr 14, 2014 8:30 pm
PA can not be used at this point, sorry. There is no suitable quality implementation on any branch by any author. Anyone that tells you otherwise is likely a sub-standard developer who you should not trust.
Tue Apr 15, 2014 9:37 am
