Two-Stroke use cases
Posted: Sat Aug 04, 2012 8:41 pm
From a decoder perspective we have three main cases:
Per cylinder, aka, distributor style patterns could be generated from the crank just as much as the cam, if not for the distribution of spark issue. On a two-stroke per-cylinder could only be done from the crank.
So, then, the following cases exist:
- Per cylinder (usually cam based)
- Per revolution (crank based)
- Per cycle (usually cam based)
- Four stroke, cam sync signal, 720 cycle
- Four stroke, crank sync signal, 360 cycle repeated twice
- Four stroke, per-cylinder sync signal, 720/cyl-count cycle, repeated cyl-count times
- Two stroke, crank sync signal, 360 cycle
- Two stroke, per-cylinder signal, 360/cyl-count cycle, repeated cyl-count times
- Wankel, "crank" sync signal, 360 cycle
- Wankel, per-combustion signal, 360/rotor-count cycle, repeated rotor-count times
