Two-Stroke use cases
From a decoder perspective we have three main cases:
  • Per cylinder (usually cam based)
  • Per revolution (crank based)
  • Per cycle (usually cam based)
For two-stroke use per-cycle is also per-revolution and crank based with a full pattern of 360 degrees. That is to say, the per-cycle 720 degree decoder setups are not used on 2 strokes.
Per cylinder, aka, distributor style patterns could be generated from the crank just as much as the cam, if not for the distribution of spark issue. On a two-stroke per-cylinder could only be done from the crank.
So, then, the following cases exist:
  1. Four stroke, cam sync signal, 720 cycle
  2. Four stroke, crank sync signal, 360 cycle repeated twice
  3. Four stroke, per-cylinder sync signal, 720/cyl-count cycle, repeated cyl-count times
  4. Two stroke, crank sync signal, 360 cycle
  5. Two stroke, per-cylinder signal, 360/cyl-count cycle, repeated cyl-count times
  6. Wankel, "crank" sync signal, 360 cycle
  7. Wankel, per-combustion signal, 360/rotor-count cycle, repeated rotor-count times
Currently the scheduler uses a 720 pattern to do its math even for a sub-720 decoder. I may need to change this to simplify 2 stroke and rotor use.
Re: Two-Stroke use cases
Did I miss anything? Is anything wrong? Thanks for confirming and/or denying!
SleepyKeys
Post by SleepyKeys »
I always thought of it like this for general pondering:
A cam sync signal on a four-stroke = a crank sync signal on a two-stroke.
"Currently the scheduler uses a 720 pattern to do its math even for a sub-720 decoder. I may need to change this to simplify 2 stroke and rotor use."
Cant you just multiply the *movent and keep the same back-end logic?
-sean
You snooze, you lose!
