Low battery starting issues with missing tooth.
Spudmn
Re: Low battery starting issues with missing tooth.
Post by Spudmn »
I changed my tolerance to
unsigned long tolerance = (smaller * TOLERANCE_LEVEL) / 1800; // TODO un hard code this. currently 25% tolerance
The car started up straight off :D
Divide by 1800 is 56% tolerance which is not great, but it works for my set up as it is now.
em_knaps you might want to try
unsigned long tolerance = (smaller * TOLERANCE_LEVEL) / 2048;
and see how you get on.
Issue tracker, good enough, I clarified. Thanks for registering :-)
Tolerance change, you're supposed to do it in the define, but that works too :-) Glad it helped. Did you need to go that far?
I'll hit him up now if he's still awake.
Spudmn
Post by Spudmn »
yes. I didn't want to. according to what I saw in the LA logs and my unit testing my teeth spacing is all over the show.
This setup works well if the crank speed is constant or you have more teeth than I do.
I will do some more testing after this weekend. I want to find out if it is my trigger wheel or just my old starter motor.
em_knaps. If it doesn't work after changing the tolerance, post a log of you cranking. I know what to look for now.
Re your RSI. Get well soon. If I can help in any way let me know.
How does the LA trace look at steady 2k or so? Whats needed is var tolerance with rpm, an issue already exists :-)
Push your test setup please? SUPER curious about that. Messy is fine, new branch, done deal, etc. I have some ideas about unit testing the decoders, but didn't start on it, wonder if you went the same way :-)
PS typed with 1 hand, hence brief
Spudmn
Post by Spudmn »
Fred wrote:How does the LA trace look at steady 2k or so?
2k was going to be my next test to see if it is my trigger wheel that is the problem.
Agreed. Or if it knows that it is cranking, then a wide tolerance and when it is running a much smaller tolerance.
I will keep you posted.
Spudmn
Post by Spudmn »
Fred wrote:I have some ideas about unit testing the decoders, but didn't start on it, wonder if you went the same way :-)
I just ripped out the ISR and all it's vars that it needed. Stuck it in one C file and complied it with GCC and ran it on the PC. I had an endian problem but it worked for the most part. I looks like a mess but it worked. I then mocked up the timer tick values and called the ISR.
I think your idea was to run unit tests remotely on the hardware which is a good idea.
I only got into Unit testing last year but it is a great way to build embedded code fast on a PC and have some confidence that it will work well when ported to the target platform.
yep, two steps of tolerance is still variable, exact method not decided yet. If it starts and runs with an even 50% tolerance, that's ok. More = overlap = not ideal.
OK, cool, more or less what i was thinking, then :-)
I have some other ideas for on the device too. Can you email me it? still keen to see your work :-) I love unit testing <3
em_knaps
Post by em_knaps »
hey Spudmn,
the slater syncs instantly with the value at the "2048" you suggested.....
although it is only running on two, but that could be an unrelated issue as the car has been sitting for a while.
will investigate further tomorrow.
Context:
em_knaps: and it runs on two cyl that use separate ign channels
em_knaps: but not the other two cyl that use those same channels
stuck injectors? shorted to ground inside plugs? something odd.
Spudmn
Post by Spudmn »
em_knaps wrote:hey Spudmn,
Good to hear. Looks like a nice day to work on it.
