XGATE PIT based bit bang fuel injection
Re: XGATE PIT based bit bang fuel injection
Right, not surprising, if there are no competing interrupts, and there aren't right now, then you will have no jitter, which is the whole point of doing it in a sequential way. If they have to compete, then you'll get peak jitter of the runtime of the opposing interrupt. Only if they are competing, though, ie, trying to run at the same time. if they're interleaved, there will be no jitter, just a slight latency.
Aim for ignition goodness, I think you are already by your questions earlier today :-) Good man, keep it up.
SleepyKeys
Post by SleepyKeys »
Fred I really need a way to view memory . I was thinking something like a request packet containing an s12x memory address and nBytes that will cause it to respond with what I requested. If you think its faster for me to just order a BDM I can do that.
thx!
You snooze, you lose!
It'd be faster for you to send a packet to the existing debug function over serial :-p
case retrieveArbitraryMemory:
It's in the comms specification document, you didn't even have to look at the source to find it :-)
Hope that helps.
SleepyKeys
Sweet thx!
Some motivation for you mate! Me with PIT ignition mostly working, 4th May 2008 ;-)
http://www.youtube.com/watch?v=ti-Qe3Q9-ZM
I was just looking for another vid and saw this and thought I'd use it to wind you up!
SleepyKeys
Depends on how you define "mostly working" to use that code on an engine would be considered murder in the first degree ;) But yeah its still a bit more than I have. Good wind up though, better get out my TA card and test what I did last night ;). ASM coding is slow unfortunately....
The later variants of it were better. Without the interrupt load of the main core interferring it almost certainly would have worked well.
BTW, can you give me two things:
An init your shit function
A shutdown your shit function
Even if they're the same function with different arguments.
Or is that not necessary? Just thinking about always on/stop/wait/sleep etc. Can I just turn off XGATE all together and run a C S12 side function to clean up your memory? I should probably run something like that to init it all in the first place, right?
SleepyKeys
Hmmmm yeah I can do that. What if you bring back the S12x and an xgate interrupt fires before the xgate module is backup and running ? I'm sure its easy just need to test.
All interrupts will be masked while down anyway. We can just turn the XG back on before enabling the interrupts. You must do something like this at boot time anyway.
SleepyKeys
Everything is moving along decently except one weird issue. If I write the same value over and over to portB I get different LEDs lit up. For example.
STB R6, R4, #ZERO_OFFSET ;bang register with new value
; STB R6, R4, #ZERO_OFFSET ;bang register with new value
brk
The first time I will see the contents of R6 on portB, register R4 contains the address of portB. But if I issue that statement multiple times I get different results, anyone have a clue as to whats going on? I used CW to disassemble my code and its verbatim what I have in my src.
