viewtopic.php?f=56&t=1180&p=33804#p33804 new feature available via manual patch for the time being.
J Series sync confirmations tested OK!
And loss of sync confirmations:
Check list for 256 for me:
  • Core framework code DONE! TESTED!
  • Even teeth + sync DONE! TESTED!
  • J Series decoder DONE! TESTED!
  • Hall effect dizzy DONE! TESTED!
  • Missing teeth DONE! TESTED!
  • GM LT1 CAS DONE! TESTED by Sean0!
  • MitsiAndMazda-CAS-4and1 DONE! TESTED!
  • MitsiAndMazda-CAS-4and2 DONE! TESTED!
Mazda 4-1 with starting setting of 0x20 or 32 confirmations:
DSM/Miata 4and2 decoder done!
Missing tooth done too! Just Sean's testing to go now :-)
No screeny or log from Sean, but he tested and what he said aligned with what I have done, so I will consider the LT1 code change confirmed.
All done. Just a few small documentation tidyups and so forth and I'll push it to dev.
It is HIGHLY RECOMMENDED that you UPGRADE IMMEDIATELY to this code, or some derivative of it.
If your tune is already in my hands, that'll be easy as pie for you, if not, get your tune into my hands ;-)
http://issues.freeems.org/view.php?id=256 Resolved-fixed! :-)
Please test on your vehicles, this should be a solid improvement for everyone. Default settings are instant start, and 10 confirmations while running, which will make it VERY obvious if you lose sync, which is a good thing IMO.
Onward and upward!
For those who have kept their config and tune up to date in the source, you
can simply download the latest image from here and throw it into your car:
http://builds.freeems.org/firmware/dev/images/
For those that have not, work with me to make that true in future as I plan a lot of updates very soon.
Locked
