Fred wrote:The column is already called "Freescale intended use" and there are cpu internal, external etc names also. Not sure what you are looking at/talking about there.
From this thread http://www.diyefi.org/forum/viewtopic.p ... 2&start=10 I used the PDF titled TA_XDP512_Xref_table_v1_1.pdf. The column next to GPIO is called "Ignition ouput driving"
Sounds like you already updated that for this next release.
I haven't changed anything, perhaps Dave's formatting moved it around or something?
I was trying to add the Doxygen zip file to the 0.0.17 release, but after it uploaded, it wouldn't show up allowing me to add it to the current release. Is that a SF thing. Any ideas how to get it added to the release.
I'm currently uploading the un-zipped version to the web space.
Did you remember to cd uploads ?
I've added the .17 Doxygen files to the SF download page, found here
https://sourceforge.net/project/showfil ... _id=639614
I've also included the Doxyfile for use with doxywizard.
Hmmm, should I look for a new pin-out in these files? Or is that a ghost yet to pass. I guess Christmas is in the air already.
Appears the upload problem was because it had the same name as another file already uploaded. So I changed the name and it then appeared int he list to attach.
Yes, your file names must be unique (preferably versioned) to upload.
No changes in the pin doc, but you could review the hardware compat ROUGH draft and comment on that if you wish.
Fred wrote:Yes, your file names must be unique (preferably versioned) to upload.
Would have been nice if SF gave an error message about this issue. But I figured it out eventually anyhow.
You mean FreeEMS-Hardware-Standards.odt, blasted it's an odt file. I still can't open those. Dave can you PDF these odt file(s)?
So I see this FreeMind stuff. I'll have to install that when I get home.
You know Fred, your code was quite readable before, and wow you've made this so much nicer to look at with doxygen. I've just got my first chance to look over some of the code, nicely done mate.
Thank you for the compliments :-)
A lot of it is still quite experimental, but some of it is fairly permanent. Those bits should show themselves fairly obviously.
Do you want to be on the snapshot list?
WTDeuce
Post by WTDeuce »
.odt is just OpenOffice... Which is free for Windows, Linux or Mac.
