FreeEMS_Loader
SleepyKeys
Re: FreeEMS_Loader
Post by SleepyKeys »
I was able to recreate your MSVC runtime error. I was unable to repeat it in RC5 :) . The serial settings are an odd thing. It responds to BAUD, but not anything else. I'll try with a different adapter, this adapter wont even work with EMStudio under Linux, due to the fact that you cant get ODD parity set.
http://powerefi.com/files/FreeEMS-Loade ... er-RC5.exe
You snooze, you lose!
Re: FreeEMS_Loader
Which chip-set? :-p
Hentai
Re: FreeEMS_Loader
Post by Hentai »
please don't save data to program files, use proper locations
Hentai
Re: FreeEMS_Loader
Post by Hentai »
Also forgot to mention the program should ask you what to name the file whenever you rip it, when I selected rip and verify burn it just rip the file and named it the same name as the one I was installing.
SleepyKeys
Re: FreeEMS_Loader
"Also forgot to mention the program should ask you what to name the file whenever you rip it, when I selected rip and verify burn it just rip the file and named it the same name as the one I was installing."
It does, when you explicitly click rip. The rip before load is just an automatic, in the event that you realize you made a mistake after the fact. However, I will add a user-specified setting for it.
Before I do all this, can you windows guys please download and run this: http://powerefi.com/files/FreeEMS-Loade ... irTest.exe and paste the "Home Dir ...." output in this thread.
thx
Re: FreeEMS_Loader
Hentai, he needs results from multiple win variants.
Hentai
Re: FreeEMS_Loader
Post by Hentai »
Re: FreeEMS_Loader
Sean, I get /Users/User for this box. CMD opens in there, and java and olv and bash and gimp and who knows what else also use it.
I'd say that you're on the right track with it!
Re: FreeEMS_Loader
Also, $(HELPURL) same for about and update, you should set those all to the forum general freeems section for the time being. They are visible in the remove programs window. Also, this one the size doesn't show up at all, just blank might be a win defect, tho.
Re: FreeEMS_Loader
Good point from hentai on irc:
C:\Users\User>echo %appdata%
C:\Users\User\AppData\Roaming
C:\Users\User>cd AppData
C:\Users\User\AppData>cd Roaming
C:\Users\User\AppData\Roaming>dir
 El volumen de la unidad C no tiene etiqueta.
 El número de serie del volumen es: 02B0-5034
 Directorio de C:\Users\User\AppData\Roaming
01/08/2012  21:20    <DIR>          .
01/08/2012  21:20    <DIR>          ..
09/01/2011  02:15    <DIR>          Adobe
09/01/2011  02:47    <DIR>          Apple Computer
28/09/2010  01:38    <DIR>          ASUS WebStorage
09/01/2011  02:44    <DIR>          FreeCDRipper
22/09/2012  23:08    <DIR>          gtk-2.0
14/07/2009  06:54    <DIR>          Identities
28/09/2010  01:08    <DIR>          InstallShield
14/01/2011  21:25    <DIR>          KeePass
28/09/2010  01:26    <DIR>          Macromedia
09/01/2011  02:56    <DIR>          Malwarebytes
14/01/2011  20:36    <DIR>          Media Player Classic
13/09/2012  20:58    <DIR>          Mozilla
09/01/2011  02:54    <DIR>          OpenOffice.org
24/08/2012  02:32    <DIR>          Skype
24/07/2011  18:51    <DIR>          skypePM
14/01/2011  21:00    <DIR>          TuneUp Software
27/07/2012  00:43    <DIR>          vlc
09/01/2011  02:51    <DIR>          Win7codecs
14/01/2011  20:35    <DIR>          WinRAR
               0 archivos              0 bytes
              21 dirs  71.462.322.176 bytes libres
