14point7.com SLC_OEM I2C Support
Re: 14point7.com SLC_OEM I2C Support
I have a soldering iron too, and a new flat with a decent sized desk, and I assembled one of these today. I need to buy some more wire and connect it to the FreeEMS CPU in various ways and run the sensor through a candle to get a varied reading over ADC, then I can begin I2C dev for it. This is a lower priority than some of the other work, but should be fun, so I'll squeeze it in in the evenings while sipping wine :-)
I'm planning to fit a tail pipe sampling tube and run the cable in through the boot/hatch and steal power from the ciggy socket to run it and a FreeEMS board too. Then I can go for a drive and do a datalog of it under various driving conditions such as cold start, idle, full throttle, trailing throttle, etc. This is all on a diesel, so it'll be interesting for me. It's a computer controlled diesel too, with traction control and what feels like drive by wire (fuck i hate that...). Maybe I can tap into the crank / cam / temperature sensors too and get a decent picture for how it behaves. But, first things first, verify that this thing works properly and get some readings from a real car with it.
I'm excited about this! :-)
Another cold day today, unable to focus on code, so built a second one which, for the time being, I'll use only on the bench. The first one is close to ready for a ride in a car. If it's cold tomorrow I'll finish the FredStim off first then go back to bed for coding in bed for the rest of the day :-/ Gotta get some work done on the firmware again soon, so this will have to wait a bit.
sry_not4sale
Post by sry_not4sale »
I'm interested to hear about your experience with this and how it compares to other similar products.
nhtshot
Post by nhtshot »
I've got a gazillion miles on them and they're great. The floating point bit is a little annoying, but manageable.
Alan is also a great guy to deal with anytime you need anything.
nhtshot wrote:I've got a gazillion miles on them and they're great. The floating point bit is a little annoying, but manageable.
Newer versions have fixed point in them.
sim
Post by sim »
According to an article on autospeed.com, the Honda Insight can cruise as lean as 25:1.
Something to consider when choosing practical limits.
http://autospeed.com/cms/title_Giving-t ... ticle.html
Is it DI? If so, it's not overly relevant. In any case, if things change, so can scalings/limits, it's not like a diamond ;-)
molak
Post by molak »
Hentai wrote:I know its doubtful anyone would do it with freeEMS right now but the bosch automotive handbook does mention with direct injection engines running as lean as lambda = 4
That's only possible with DI. They use a stratified mixture , just above stoic around the spark plug and really lean elsewhere..
Correct, and then the question becomes "Will FreeEMS do DI" and the answer is "Not now and not soon, but maybe, in the distant future.".
