So I'm doing an audit of other peoples github forks to see what should be removed:
- AndrewGauger: even.teeth.edge.fix (master could do with a rename too)
- malcom2073: even.teeth.edge.fix (master could do with a rename too)
- johnsop1: release (master could do with a rename too)
- Preston: (master could do with a rename)
- DeuceEFI: (DeuceCoupe and S10 could do with renames, you're using the build server/HEAD, right?)
- evortriede: (master could do with a rename)
- simeonveldstra: (dev could do with a rename or delete if you're happy with the commit that replaced it)
Matthijs309: cross.compile.test.example, even.teeth.edge.fix (master could do with a rename too)toxicgumbo: PetersSpecialJBranch, DeuceCoupeIATandMATpotBuild, DeuceCoupeTempBranch, DeuceCoupeTempTimingHooray, DeuceCoupeTestShortDwell
I've created a new repo here that you should NOT fork from which I'll push temp branches to as required:
https://github.com/fredcooke/freeems-temp
Get this by running this command:
git remote add shared.branches https://github.com/fredcooke/freeems-temp.gitCode: Select all
git fetch shared.branchesFred.
