So, getting to that, why do you not like using the MAT? Just because it is so prone to error? (That's ENTIRELY reasonable)
My question is, if you had a 100%, idealized MAT, with no radiative coupling, no heat soak, it just somehow knew the exact temperature in real time of the air in a particular place.... Why would you mount it outside of the manifold?
I would think you'd want the MAP and MAT to be in the same place at the same time, since really you're just counting molecules/sec entering the engine.
If it were me, I'd have four flow meters, one in each runner, and do my fuel and timing based on that, with direct injection.
