Page 4 of 4
Re: Arttu's MS3 compatible processor board
Posted: Tue Sep 23, 2014 10:48 pm
Neat! How many did you get made? Do I get a blank souvenir? :-D
For future spins you need to choose a name for it. It's ok to put FreeEMS on it, but not as part of the name. Something like "Designed for FreeEMS" or similar is appropriate. Same goes for ruzki, and everyone else, too.
How about EmmEssFree? A play on MS3 and speech impediments :-)
Posted: Wed Sep 24, 2014 6:16 am
by Arttu
Fred wrote:Neat! How many did you get made? Do I get a blank souvenir?
Sure! I got ten boards so there are some spares. I can probably arrange an assembled board for you if think you would have use for it.
I know. I just have poor imagination and couldn't come up with any sensible name. Not a bad suggestion, I'll think about it
Posted: Wed Sep 24, 2014 7:46 am
by reanimotion
Fred wrote:How about EmmEssFree? A play on MS3
+1 ! although I'd drop the double m -> "EmEssFree"
Posted: Wed Sep 24, 2014 9:22 am
by DonTZ125
If you're keeping this MS3 compatible, where's the stepper driver and CAN chip?
Or am I going blind in my old age?
Posted: Wed Sep 24, 2014 11:36 am
by Arttu
The CAN chip is there, page 3 of the schematic. I dropped off the stepper driver since I haven't seen any plans to support it in the firmware (of course I might be wrong on this).
Posted: Fri Oct 17, 2014 10:36 am
by Arttu
Posted: Fri Oct 17, 2014 11:08 pm
Neat! :-)
Posted: Tue Nov 25, 2014 12:53 pm
by Crystallattice
Arttu, do you have the design files available for this daughter card you designed? I only find the pdf versions. I really like what you did and want to do something similar and your design will be a great starting point.
Posted: Mon Dec 29, 2014 8:23 pm
by JaniM
Some test done with this. Works trigger in and gives pulse out from ignition and injectors channels. Outputs is tested only with scope. Next thing to test via Emstudio, when get some time.
