View unanswered posts | View active topics It is currently Fri Nov 27, 2020 6:32 am
Reply to topic  [ 39 posts ]  Go to page Previous  1, 2, 3, 4
Arttu's MS3 compatible processor board
Neat! How many did you get made? Do I get a blank souvenir? :-D
For future spins you need to choose a name for it. It's ok to put FreeEMS on it, but not as part of the name. Something like "Designed for FreeEMS" or similar is appropriate. Same goes for ruzki, and everyone else, too.
How about EmmEssFree? A play on MS3 and speech impediments :-)
Tue Sep 23, 2014 10:48 pm
Sure! I got ten boards so there are some spares. I can probably arrange an assembled board for you if think you would have use for it.
I know. I just have poor imagination and couldn't come up with any sensible name. Not a bad suggestion, I'll think about it :)
Wed Sep 24, 2014 6:16 am
+1 ! although I'd drop the double m -> "EmEssFree"
Steve
1981 Porsche 928S Bosch KE3-Jetronic Injection with FrankenCIS http://www.FrankenCIS.com
Wed Sep 24, 2014 7:46 am
If you're keeping this MS3 compatible, where's the stepper driver and CAN chip?
Or am I going blind in my old age? :D
TTR Ignition Systems
Wed Sep 24, 2014 9:22 am
The CAN chip is there, page 3 of the schematic. I dropped off the stepper driver since I haven't seen any plans to support it in the firmware (of course I might be wrong on this).
Wed Sep 24, 2014 11:36 am
Some progress. I assembled the first board. After some struggling I managed to flash the bootloader on it and load benchtest code in. Then I was able to connect it with the EMStudio. Wohoo! I guess the next step is to learn how to make my own build configurations and put together a code version that allows testing with real engine.
Fri Oct 17, 2014 10:36 am
Neat! :-)
Fri Oct 17, 2014 11:08 pm
TO92 - Vaguely active
Arttu, do you have the design files available for this daughter card you designed? I only find the pdf versions. I really like what you did and want to do something similar and your design will be a great starting point.
Tue Nov 25, 2014 12:53 pm
Some test done with this. Works trigger in and gives pulse out from ignition and injectors channels. Outputs is tested only with scope. Next thing to test via Emstudio, when get some time.
Mon Dec 29, 2014 8:23 pm
