View unanswered posts | View active topics It is currently Fri Nov 27, 2020 7:35 am
Reply to topic  [ 214 posts ]  Go to page Previous  1 ... 17, 18, 19, 20, 21, 22  Next
Dan's PNP RB25DET R33 Skyline ECU PCB
For desoldering a connector you could also use a heat gun.
Thu Jan 30, 2014 6:18 pm
Still difficult to get enough pins heated at the same time on those big ECU connectors.
FABRICA MI DIEM, PVNC!
Fri Jan 31, 2014 9:37 am
I use an electric skillet to reflow my little boards. The same principle should work for dismounting a connector - melt all the solder at once, lift off the device. You may need a helper to hold the board still.
TTR Ignition Systems
Fri Jan 31, 2014 7:28 pm
the 76-pin connector could be removed easily...
Sat Feb 01, 2014 10:06 am
OK so I have found the issue relating to why I cannot communicate via the BDM interface.
I hate to admit this, but I soldered the damn cpu IC incorrectly oriented (ie. pin 1 was not where it should have been).
Several EPIC LOL's later at my n00b-ish failure, I managed to damage the pcb removing the cpu IC.
I had two alpha pcb's here, so I started fitting a new cpu IC to the second alpha pcb.
EPIC failure again as I managed to pick a damaged IC out of my component tray and didn't realise until I had soldered most of the pads.
I then proceeded to damage the second pcb whilst attempting to remove the cpu IC.
So...... long story short, I have identified the problem (which is me, the assembler, and not any fault of the pcb).
I will be pushing some minor changes to the pnp pcb in the very near future to correct some component placements that I don't like. (ie. they come close when fitted to the stock ecu enclosure)
More PCB's will be ordered after those changes are made and as a result of my n00b-ness....... (this will happen today/tomorrow)
Fuck I feel like a complete n00b........ shit happens I guess :-P
Sun Feb 16, 2014 3:35 am
ROFL! Respect for having the balls to tell the world! :-D People make mistakes, even perfect people like you ;-)
Sun Feb 16, 2014 3:38 am
I'm far from perfect LOL
I am happy it was my mistake and not a fault on the PCB though :-)
Pushing changes soon and then I will be placing another small PCB order :-)
Sun Feb 16, 2014 3:48 am
Good stuff! Keep it up :-)
Sun Feb 16, 2014 8:21 am
Decided not to do any changes to the alpha PCB design yet.
Just asked for a quote from my Australian PCB supplier.
Should be ordering another small pcb batch today! :-)
Sun Feb 16, 2014 10:34 pm
Two more alpha boards are ordered! they are being shipped tomorrow, should have them Thursday *fingers crossed* :-)
Mon Feb 17, 2014 7:05 am
