View unanswered posts | View active topics It is currently Mon Nov 30, 2020 2:38 am
Reply to topic  [ 72 posts ]  Go to page Previous  1 ... 4, 5, 6, 7, 8  Next
flat4power's Guepard - a VW type 1 oriented board
ok so remove ;)
git is now up to date :)
Wed Jun 19, 2013 11:23 am
flat4power:
What version of KiCAD are you using?
Thank you,
Wed Jun 19, 2013 1:01 pm
I'm using Kicad(2013-05-16 BZR 4016)
I have change my schematics for MPX4250, because I have used the wrong footprint like you say
github is now update
Matthieu
Wed Jun 19, 2013 1:08 pm
I realize this board this week to proceed some test.
Can you say me if I need realize some modification or can I test like that ?
Matthieu
Mon Jun 24, 2013 8:49 am
Free English lessons ;-)
flat4power wrote:
I realize this board this week to proceed some test. < understood
flat4power wrote:
I will make this board this week to proceed with some tests. < better
flat4power wrote:
I will make this board this week to do some tests. < good
flat4power wrote:
I will make this board this week to do some testing. < best
Are you going to etch it at home yourself?
flat4power wrote:
Can you say me if I need realize some modification or can I test like that ? < understood
flat4power wrote:
Can you tell me if I need to do some modifications or if can I test like that ? < better
flat4power wrote:
Can you tell me if I need to make some changes or if can I test like that ? < good
flat4power wrote:
Can you tell me if I need to make some changes or if can I test it as it is ? < best
I don't have time to check it over, but if you hold off until Dan and/or Andy have had a poke around, that would be a good idea.
Mon Jun 24, 2013 12:25 pm
thanks for the lesson ;)
I will try to do better next time :)
I entrust the implementation of the pcb because I do not have the resources to do
Ok, I'll wait a little to have a feedback from Dan and/or Andy :)
Mon Jun 24, 2013 12:39 pm
In that case, the correct form would be:
I will have this board made this week to do some testing.
or
I will get this board made this week to do some testing.
or
I will have this board manufactured this week to do some testing.
Mon Jun 24, 2013 2:16 pm
Matthieu,
After reviewing your PCB layout in KiCAD, I have found the following areas you will want to correct before having boards manufactured:
1. Take a look at where you feed power into your decoupling capacitors for the MCU, you need to feed the power into the polarized tantalum capacitors then route to the ceramic capacitors before finally routing to the MCU pins. Specifically power into C47, then to C2, then to the MCU pin. Same scenario for C48 and C3.
2. C4 and C44 shouldn't be in parallel, C4 should go to one pin of the MCU, the C44 to the MCU pin next to the one C4 is connected to. Here again make sure to feed power to the capacitor before routing into the MCU pin.
3. The RPM-Crank-IN+ and RPM-Crank-IN- traces in the corner under U11 are close together, try to keep them the same distance apart in the 45degree angle traces as you did before and after the 45degree angle.
4. The ground plane under the Freescale MCU should look like the suggested PCB design in the Freescale 9S12XDP512 datasheet. If you open up my Jaguar 0.4-alpha board layout in KiCAD you will see the correct shape it is to look like.
Once you get those corrected I can take another look to make sure there are no other issues.
Thank you,
Andy
Wed Jun 26, 2013 8:37 pm
thanks for your feedback
I worked on changes
Github is updated
Thanks
Matthieu
Thu Jun 27, 2013 10:31 am
In my schematics I have this for bluetooth communication (3.3V module)
But is it possible using ADUMX201 (like on USB communication) as an level converter between MCU 5V and bluetooth 3.3V.
thanks for your help
Mon Jul 01, 2013 1:23 pm
