flat4power's Guepard - a VW type 1 oriented board
Re: Guepard board
Check rav/jag schems again, their load/CEL circuits do not look like yours.
Re: Guepard board
My thoughts:
1. Double check your CEL/Load circuit as Fred suggested or you will fry the input pin on the MCU.
2. Rename MAT to SPR1 or delete it, as it isn't currently used for anything, it is a spare input.
3. In your crystal circuit, make sure to use the crystal manufacturer's suggested load capacitors, they might not be 20pF like I used.
4. Do you have access to a 1 pulse per engine cycle (commonly called a camshaft angle sensor)? If so, you can time the injections to the cylinder firing order, otherwise it will be untimed batch injection.
5. Double check your MAP and AAP sensors you want to use, the MPX4250AP 6 pin through hole sensor and the MPXA6115AC6U 8-SOP 8 pin SMD sensor have different pin outs and you can not connect the 8-SOP to the 6 pin through hole pinout or you will fry the SMD sensor.
6. Make sure to note that most resistors (except the 1k and 3.9k BRV resistors, and the IAT/SPR1/Coolant 2.49k resistors, which should be 0.1% tolerance or better) should be 1% metal film resistors.
7. The other resistor exceptions are your R18 and R19 should be 10k ohm 2W resistors if you are using a Variable Reluctance (VR) RPM sensor.
8. On your Outputs schematic, I'm a little confused as to the purpose of the XOR since you can choose TC442x ICs that have 2 non-inverting, 1 non-inverting/1 inverting or 2 inverting outputs. If you are using something like GM LS1/LS2 5v logic level coils, you would use a TC4427 IC (2 non-inverting outputs).
9. I would add pin 6 on your DB-25 connector should be RPM-Crank-Shield (GND).
10. Same DB-25 connector, I would add pin 24 to be another injector ground.
11. Since you used the Jaguar and RAVage schematics, make sure to include the LICENSE.TXT file, my Jaguar is licensed under GNU GPL version 2.
12. Dan or Fred will need to look at your Digital Inputs, as I don't have any on the Jaguar PCB.
That's all I can think of for now, other than the above points you have a good start
Re: Guepard board
Thamks! All good, cept:DeuceEFI wrote:My thoughts:
Not true. All injection in FreeEMS is timed. With crank only you get two pulse per cycle timed semi-sequential injection. It is batch, but not how batch is commonly understood (all four wired up together).4. Do you have access to a 1 pulse per engine cycle (commonly called a camshaft angle sensor)? If so, you can time the injections to the cylinder firing order, otherwise it will be untimed batch injection.
Post build configurability is the reason to do that.8. On your Outputs schematic, I'm a little confused as to the purpose of the XOR since you can choose TC442x ICs that have 2 non-inverting, 1 non-inverting/1 inverting or 2 inverting outputs. If you are using something like GM LS1/LS2 5v logic level coils, you would use a TC4427 IC (2 non-inverting outputs).
+1 More == merrier, 1 per other signal, optimally.9. I would add pin 6 on your DB-25 connector should be RPM-Crank-Shield (GND).
RavAGE schematics will likely be permissively free, so that's no big deal/desired. It looked to me like he'd used some of your files, though, but I could be wrong.11. Since you used the Jaguar and RAVage schematics, make sure to include the LICENSE.TXT file, my Jaguar is licensed under GNU GPL version 2.
Easy to make work, hard to make optimal. See this: viewtopic.php?f=58&t=201212. Dan or Fred will need to look at your Digital Inputs, as I don't have any on the Jaguar PCB.
Re: Guepard board
the way your current CEL circuit is configured WILL burn your cpu when the jumper is installed (there is nothing to limit current from the CPU pin to ground)
this is how it should be
Your PLL circuit appears to be correct (I am just looking at the *important* circuits in detail)
You can get crystals which are stable from 18pf - 22pf, but using caps that are 18pf gives you more choice when it comes to selecting a crystal for your CPU clock circuit. Fine as it is, but change it if you feel the need.
I would also remove the 5V6 zener from the output of your micro +5v regulator circuit, as I don't feel it is required (I am unsure of your setup exactly though).
Also, why such a large (47uF) capacitor on the output of this regulator? (purely out of curiosity)
Nice work!
Keep it up!
Dan
Nice work!
Dan
- flat4power
Re: Guepard board
Hi,
I made some modifications with your help
power circuit:
injectors circuit:
ignition circuit:
Matthieu
power circuit:
injectors circuit:
ignition circuit:
Matthieu
Re: Guepard board
Matthieu, you don't need the XOR chips for a normal configuration, they're purely for a fully configurable box. Simplify that a LOT by removing them. You don't need dual supplies, and it's more trouble than it's worth for a simple setup. Your regulators DEFINITELY NEED heatsinks, so build that into the design too. I'd rock a single LM2940 if I were you. The fancy clamp is also only for idiot installations, not strictly necessary and a simple 3W 5.6V zener will *probably* (not definitely) protect you from small mistakes. However it's all 100% OK as is to my eyes. Good work.
Re: Guepard board
Yep
What Fred said!
Looking good mate!
What Fred said!
Looking good mate!
- flat4power
Re: Guepard board
I don't understand that. sorryFred wrote:The fancy clamp is also only for idiot installations, not strictly necessary and a simple 3W 5.6V zener will *probably* (not definitely) protect you from small mistakes.
I'm going modify what you say now
ignitors circuit:
Re: Guepard board
Top right is fancy clamp: http://imageshack.us/a/img69/3355/powerwn.png
- flat4power
Re: Guepard board
like that ?
