PC Utility To Sweep RPM With The MissingTooth Hack BenchTest
A place for small project requests from the team to exist and grow into something fully fledged and useful to the masses.
Dumped from IRC and rearranged to be more useful and less random:
[21:32] <@FreeAir> still need a PC utility to pump data into it, i want to sweep rpm, triangle style is fine for a start
[21:33] <@FreeAir> send a stop logging packet, hard coded
[21:33] <@FreeAir> send a bench test setup packet, partly hard coded, pull number of base teeth from the command line --BaseTeeth=12/36/24
[21:33] <@FreeAir> send many rpm adjust packets, mostly hard coded, just checksummed and escaped afterward
[21:33] <@FreeAir> you could add an adjustable pause between to optimise it from the command line with --InterPacketPause=3ms
[21:33] <@FreeAir> have a function RPM vs time
[21:33] <@FreeAir> pull the rpm out of the function for each packet
[21:33] <@FreeAir> based on time
[21:34] <@FreeAir> bonus points for displaying current RPM in a UI of some sort, even if it's a console line
[21:36] <@FreeAir> so you could A stop logging, B start the test C display RPM and pump out RPM
[21:38] <@FreeAir> cycleFreeEMSBenchTestRPMHack --Pattern=triangle --StartRPM=50 --MinRPM=50 --MaxRPM=7000 --SweepPeriod=10s
[21:38] <@FreeAir> something like that, only triangle for now, hard code that if you like, or error on other stuff
[21:43] <@FreeAir> max out the iterations
[21:38] <@FreeAir> you can write to the read only structs when you have bench test firmware loaded, and at no other time.
[21:38] <@FreeAir> so the new hack just reads from that and uses it for the slice period
[21:39] <@FreeAir> sample RPM set packets are in the lib dir
[21:39] <@FreeAir> same for stop logging and bench test packets
https://github.com/fredcooke/freeems-va ... 0x0200.bin
https://github.com/fredcooke/freeems-va ... 0x0400.bin
https://github.com/fredcooke/freeems-va ... 00-OFF.bin
https://github.com/fredcooke/freeems-va ... rallel.bin
Packet structure: https://github.com/fredcooke/freeems-va ... cation.tex
[21:45] <@FreeAir> you can ignore all the return packets and just flood the line with a continuous stream
[21:39] <@johntramp> ok, i should read up on the bench test firmware
[21:39] <@johntramp> there must be a thread somewhere, right?
viewtopic.php?f=56&t=1180
[21:40] <@FreeAir> in fact, i think it's in the latex now
https://github.com/fredcooke/freeems-va ... erface.tex
You need to calculate the RPM from number of ticks per event, number of events per cycle, or vice versa, a cycle is a revolution in this mode.
To trigger the mode, set one of the PWs to 3, and the rest to not-3, then all that matters are the first three values. The "which event" values don't matter. The "how many cycles" should be maxed. 5 of the PWs don't matter. Events per cycle = base teeth. Ticks per event = related to RPM via this formula:
60000000 / (baseteeth * toothperiod * 0.8)
from this post: viewtopic.php?p=20967#p20967
[21:45] <@FreeAir> just a little single C file would be OK
[21:46] <@FreeAir> let me do a thread from the above conversation to clean it up for you
Done! :-)
Re: PC Utility To Sweep RPM With The MissingTooth Hack Bench
John, your fish/info, laid on a platter for your consumption ;-)
 00 77 77 01 0C FF FF ?? ?? 00 00 00 00 00 00 00 03 00 00 00 00 00 00 00 00 00 00
Which breaks down into the following:
0x00 flags - correct
0x7777 payload ID - correct
0x01 mode - correct
0x0C events per cycle / base teeth = 12/0x0C for default, 36/0x24 for common
0xFFFF cycles, max this out
0x???? ticks per event / effective rpm - set this dynamically, this is the initial value only
00 00 00 00 00 00 - zeros for ease of manual checksum verification
0x0003 This triggers the special mode
0x0000 irrelevant as long as it's not 3, zeros easy to count
Hard code, 'cept the RPM and base teeth.
Thanks John! :-)
Available in hash 0c30416ff4faa40e2bbdce06762ff27355b3eae8
Currently from my repo https://github.com/fredcooke/Lacerated-Pempheridae
Though John will pull it in soon, I guess! :-)
Combo with OLV, BenchTest, two normal firmware versions, this 6, MTX, and Preston :-)
http://www.youtube.com/watch?v=CIjvVGdKxgk
https://github.com/johnhowe/Lacerated-Pempheridae
^ John's master copy, more up to date right now, afaik.
http://megatunix.com/tracker/view.php?id=30
John, please update to match! Thanks :-)
johntramp
Post by johntramp »
johntramp wrote:I let Dave win that round.
ROFL! Nearly woke up the mrs with laughter at 4:30am :-p
