johntramp stumbled upon a part error in his 0.7 kit today and I verified it in my 0.7 kit too. The part wrongly supplied is a 68nF capacitor that should be 6.8nF in value. Using this wrong value will cause your clock to be of dubious quality. My high quality firmware will protect you from this issue, however it could make your jaguar behave in an unreliable fashion. Please do not install the 68nF capacitor in location C7, and if you did, please carefully remove it and replace with one with the correct value. These should be good quality caps, however should be easy to find locally for a few cents, so I don't feel that Andy should have to remedy this. Please post in this thread to confirm that you have read this and will make the necessary change.
Using the wrong value will result in a damping factor of 2.25 instead of 0.707. 0.7 to 0.9 is the recommended range for this figure.
0.6-alpha kits have been confirmed to be affected too. All such units should be repaired immediately to avoid weird behaviour from your engine.
I'll artificially create a post by Andy below to record a check list of 0.7 and
