Jaguar 0.6-alpha progress
- flat4power
Re: Jaguar 0.6-alpha progress
nice work Andy
Since the first batch of 10 Jaguar 0.6-alpha boards have arrived and I have started to build the first one to check all the changes, here are some photos, just click on the photo to see the full size image.
A pair of fresh Jaguar 0.6-alpha boards:
Sorry for the somewhat blurry iPhone photo of testing the over-voltage clamp circuit:
Testing a theory of bending the legs on the voltage regulator to prevent stressing the solder connection if the heat sink holes are mis-aligned into a common block of alloy:
Jaguar with USBDM connected to load the Serial Monitor program:
I have tested the over-voltage clamp circuit and it does clamp the Analog-5v rail at 5.16v to 5.20v when 13.6v is applied through a 1 ohm 10W resistor to the TPS-5v output.
More photos as testing continues...
I am quite excitable about your jag Andy.
I looks pretty damn cool so far. I eagerly await more pictures.
and all while Fred is in bed....counting sheep?
Love your work Andy! very impressive
You are a hero
edit: funny how much the smiley looks like a capacitor
Nice work!! I can't wait to have my Jaguar!
^^^ That!
Do. Want. One.
Do. Want. One.
Ok, I made some more progress with my build today, again click on the photos to see the full size images:
Starting point of today with Benchtest firmware loaded and no input circuits built yet:
After installing the AAP circuit components:
After installing the MAP circuit components:
After installing the BRV input circuit components:
After installing the O2 sensor input circuit components:
After installing the TPS input circuit components:
After installing the IAT input circuit components:
After installing the CHT input circuit components:
For those who are paying attention, I'm using an external MAP sensor on the S10, so I installed the onboard MAP sensor for testing the corrected pad traces. Good news is that both the AAP and MAP circuits work properly now.
Up next is testing the analog input over-voltage protection circuits before continuing the build.
Or do you mean at each individual analog input? (other than the TPS input that you have already tested)DeuceEFI wrote:
Nice work mate! Keep it up!
Or you are talking about the PNP clamp in your first post and now you are talking about the schottky's etc on the analog inputs?
