View unanswered posts | View active topics It is currently Mon Aug 10, 2020 7:16 am
Reply to topic  [ 38 posts ]  Go to page Previous  1, 2, 3, 4  Next
Rob's Rebuild Of Hentai's Old Jaguar 0.3-alpha
Just to clarify that, they shouldn't get hot *WITH* a chunk of alloy screwed to them. Without one, they will get hot. The chunk of alloy can be quite small, though. An OEM case is more than sufficient.
Tue May 14, 2013 1:04 am
I had two small radio shack heat sinks with no fan on them. no issues in my car.
didn't see how old the last post is
want updates stat!
Tue Oct 29, 2013 1:52 am
Just a heads up, the links on the first post are 404'ing.
Tue Nov 05, 2013 5:31 pm
Photos from post 1
http://fe3miata.com/site/wp-content/ima ... -jag-1.JPG
http://fe3miata.com/site/wp-content/ima ... -jag-2.JPG
Thu Nov 07, 2013 2:08 pm
I've successfully tested Hentai's A3 with the bench test FW and using a jimstim. A driver was added for the ignition outputs from JP7 & JP8. The A3 now sits inside the OE Mazda MX5 ECU case, arranged to utilize the stock wiring connector and harness. Will need to add a few more leads I'll pull from a spare harness. PCB card rails were sanded down to clear the A3's components. Those are anchored to some L brackets that attach to the case bottom. Drilled out the case side to allow MAP and USB access, and for mounting the power supply heat sinks. Heat sinks and hardware were sourced from an old Mac power supply. I'll be using an 80s Mustang GT throttle body with its stock idle valve and variable TPS (early MX5's did not have a variable TPS.) GM IAT sensor will be located somewhere between the throttle body and intercooler exit. Links to high rez below each image.
JagA3 connections to stock ECU
Utilized stock connections are represented by bright yellow. Boxes show original OE functions and small black box with white type is connection to Jaguar A3. Remaining stock connections are left unconnected.
http://fe3miata.com/site/wp-content/ima ... GA3-13.jpg
http://fe3miata.com/site/wp-content/ima ... GA3-14.jpg
http://fe3miata.com/site/wp-content/ima ... -01-1k.jpg
http://fe3miata.com/site/wp-content/ima ... -02-1k.jpg
http://fe3miata.com/site/wp-content/ima ... -03-1k.jpg
http://fe3miata.com/site/wp-content/ima ... -05-1k.jpg
http://fe3miata.com/site/wp-content/ima ... -06-1k.jpg
http://fe3miata.com/site/wp-content/ima ... -07-1k.jpg
http://fe3miata.com/site/wp-content/ima ... -12-1k.jpg
Sat Nov 09, 2013 8:56 pm
Neat! Permission to re-host some of those on everybody's most hated social media site? :-)
Sat Nov 09, 2013 9:31 pm
Sure thing! It wouldn't be FreeEMS if you needed my permission. ;)
Sat Nov 09, 2013 10:02 pm
What changes were done to the ign part of the board?
Sun Nov 10, 2013 12:30 am
JP7 & 8 (DIS bypass, IGN advance) out to a driver and then to igniter.
Sun Nov 10, 2013 6:29 pm
Where "a driver" == same as newer jags and/or RavAGE etc.
Sun Nov 10, 2013 7:01 pm
