AduM1201ARZ Isolator Hack (I hadn't cleaned off the solder resin yet at this point)
No pull up/down resistors required, just the FT232RL IC -> AduM1201ARZ IC -> CPU
It's alive! MWAHAHAHAHA!
Now to start playing around!
Dan's Jaguar PCB Build
Re: Dan's Jaguar PCB Build
I'm not quite sure how that is working... Anything older than 0.2.0-SNAPSHOT-125-gf1d97fe shouldn't work. That's actually two commits behind, it was a temporary commit that I had in my repo still, dangling.
Grab new firmware from here: http://tmp.fredcooke.com/FreeEMS-0.2.0- ... chTest.s19
And Sean's latest win loader, and upgrade! Emstudio load will be twice as fast on newer firmware too.
Please test the living shit out of the loader. Pay special attention to it respecting your settings, or not (bad settings should not successfully load!), usability, intuitive-ness, etc. File issues on tracker and link here :-)
okie dokie, will do so as soon as I get a chance.
I didn't think the version i had was going to work, I remember reading somewhere on the forums that older versions wouldn't work anymore.
I am surprised that it did!
Firmware Update Time!
Success!
Success!
- flat4power
you can install or upgrade firmware with emstudio or you use an other soft to do that ?
i use seans loader to load/erase/rip firmware.
emstudio for tuning, etc
- flat4power
ok thanks
