Fred's A3S5 Rangi/Ghetto/Hokey/Maori Jaguar Build
Posted: Fri Apr 13, 2012 3:02 pm
Because I define poor, my build will be a little different.
For a start my build will only contain CPU, comms and the firmware load jumper parts. I'll be feeding the board 5V from an external supply to get it up and running ASAP. I'll not be using an FTDI chip as I don't have one and they are extortionists. Instead I will be using another chip which I'll be evaluating in the process. I don't have the correct TH mini USB or any big USB socket/cable, so I've already modified an SMD mini USB socket to fit in the TH position correctly.
This minimal configuration will allow me to get on with creating a better SM: viewtopic.php?f=8&t=1232
Loving the outlined sub-circuits.
Considering there are already three other essential fine pitch ICs, why not save some space with the XOR being one too?
If we can't adequately solve the max square wave latency issue, I'm guessing a move to a schmidtt trigger IC for input would better suit the intended purpose of the board. If not migrate, then perhaps in parallel and only populate one circuit much like early DFH designs had.
Note for me, ground link info here: viewtopic.php?p=25650#p25650
I've taken a few pics of what Andy did for me, and serial number, and the usb connector. I'll put them in the next post. Comments welcome after that post.
