I found the AMPSEAL Sealed Connector Series on the TE Connectivity site...
Quote from the TE site:
" This wire-to-board system provides two-way sealing of the interface and wires that makes these environmentally superior heavy-duty connectors not only waterproof, but submersible as well. Connectors are available in cable plugs and pc boardmount headers. "
I have ordered the maximum number of free samples of the following (which they had in stock at SEVERAL vendors online) and they have been shipped:
QTY:1 Part# 1-776163-1 AMPSEAL 3-Row/35 position Right Angle Connector Header/color=black Gold Pins, URL: http://www.te.com/catalog/pn/en/1-77616 ... s_cid=SAM4 Price: Approximately $12 USD each, minimum is 1
QTY:1 Part# 776231-1 AMPSEAL 3-Row/35 position Vertical Connector Header/color=black Tin Pins, URL: http://www.te.com/catalog/pn/en/776231- ... s_cid=SAM4 Price: Approximately $12 USD each, minimum is 1 although this is for Tin pins rather than the Gold listed above.
The above mate with Part # 776164-1 below:
QTY:1 Part# 776164-1 AMPSEAL 3-Row/35 position Free Hanging Connector Housing/color=black, URL: http://www.te.com/catalog/pn/en/776164- ... s_cid=SAM4 Price: Approximately $9 USD each, minimum is 1
Socket Contacts below are for the Connector housing above...
QTY:25 Part# 770520-3 AMPSEAL Gold Plated Socket Contact for AWG 16-20 wires/rated 17A, URL: http://www.te.com/catalog/pn/en/770520- ... s_cid=SAM4 Price: Approximately $0.325 USD each, minimum is 5000
QTY:10 Part# 770854-3 AMPSEAL Gold Plated Socket Contact for AWG 16-20 wires/rated 17A, URL http://www.te.com/catalog/pn/en/770854- ... s_cid=SAM4 Price: Approximately $0.68 USD each, minimum is 1
Both of the above Socket Contacts are crimp connectors...
QTY:10 Part# 770678-1 AMPSEAL Plug (for unused housing positions), URL: http://www.te.com/catalog/pn/en/770678- ... s_cid=SAM4 Price: Approximately $0.22 USD each, minimum is 1
They also have different color Connector Header and Housings available, I asked for a few other colors as well...
Here is the base search URL: http://www.te.com/catalog/bin/TE.Connec ... &BML=&LG=1
This will save you from having to find it again via searching the website
