Fred wrote:Probably because you've not configured anything on it
That brings me to my next question, how do I go about configuring the firmware for the outputs? I need PT2 to be the ignition advance, PT3 to be high only when RPM is above 300 RPM. PT4, 5 and 6 will be for 3 pairs of injectors.
Fred wrote:I can help with that, but in the mean time, don't test outputs using inputs, use the bench test firmware, much better
Cool, I have attached a pic showing the benchtest firmware running with the Cam and Crank inputs from my JimStim.
Fred wrote:As for the older board, once you're 100% happy, place a processor and tack down the ground, power, config, bdm and comms pins. you should be able to load code to it with the BDM and get comms with mtx after you load firmware with sean's loader. You need to learn all that stuff anyway, so best to spend some time getting used to the process.
Cool, I have a test board I tested my reflow oven with that I am using right now for my prototype of the circuits for the Jaguar board. I will however get the CPU, optos and the ft232rl reflowed to test the comms.
Currently my prototype board is working with MTX and with Sean's loader
Fred wrote:Maybe you could document using the BDM on linux if you can figure out how. I didn't yet.
I haven't been able to get it to work properly in linux YET, so I have to boot into WinXP or Win7 to get my TBDML to work properly.
