 had steps of assembly, ie the interface circuit, the power circuit, etc. And then test procedures..What minimal parts do i need to have mounted to flash the processor with the usbdm? Maybe Andy could chime in or direct me to a/the assembly thread. Slowly building my parts collection for assembly day.
   had steps of assembly, ie the interface circuit, the power circuit, etc. And then test procedures..What minimal parts do i need to have mounted to flash the processor with the usbdm? Maybe Andy could chime in or direct me to a/the assembly thread. Slowly building my parts collection for assembly day.Jaguar 0.6-alpha progress
Re: Jaguar 0.6-alpha progress
For those who got some bare/smd/partial assembled boards, is there a step process to populate the through hole and smd components? Other diy boards (EZ Fred, no references made  had steps of assembly, ie the interface circuit, the power circuit, etc. And then test procedures..What minimal parts do i need to have mounted to flash the processor with the usbdm? Maybe Andy could chime in or direct me to a/the assembly thread. Slowly building my parts collection for assembly day.
   had steps of assembly, ie the interface circuit, the power circuit, etc. And then test procedures..What minimal parts do i need to have mounted to flash the processor with the usbdm? Maybe Andy could chime in or direct me to a/the assembly thread. Slowly building my parts collection for assembly day.Re: Jaguar 0.6-alpha progress
This does need to exist, but roughly, here goes:
									- Install clamp parts, test clamp with 1ohm or so resistor to 12 or so volts, ensure rail stays at 5.15 NOTE: If this test fails, and you have installed other parts, they will be damaged and will need to be replaced!
- Ensure your FET driver ICs suit your application (IE, save the trouble of removing/replacing wrong parts)
- install other SMD parts (best done first ahead of all TH parts)
- Install clock components and CPU decouple capacitors (required for BDM loading)
- Use BDM to load seank-hack SM from thread attachment here: viewtopic.php?p=28948#p28948
- Install FT232RL related parts, at the very least, L1 (smd so should already be done by now)
- Verify comms with CPU through USB port by loading BenchTest firmware from build server: http://builds.freeems.org/firmware/dev/images/
- Install everything else choosing these things first: viewtopic.php?f=67&t=2334
- Install power supply bits including bending legs of to220 regulators like this picture or remote mounting them slightly: http://i.imgur.com/xo7jjSZ.jpg
- Install in a case
- Plug in or wire in to a vehicle/engine
- Party
Perfect, just what i needed along with the external links for firmware.
Jaguar 0.6-alpha Assembly Guide located here: viewtopic.php?p=36648#p36648
just checking in
Any news on this yet?DeuceEFI wrote:Fred is correct, we have found a few things that needed changed and I have made a few changes already.
I'm hoping to order the next set of PCBs in mid to late December, I should know more after I see Fred in person next week
Pretty pretty please.
With a cherry on top.
Some news:
(19:24:22) DeuceEFI-git: (notice) Jaguar/dev b545f13 Andy Goss: Changed to separate Creative Commons and MIT licenses for PCB and Schematics, respectively, and updated TODO with fuel pump driver change to be made.
(19:24:22) DeuceEFI-git: (notice) Jaguar/dev 786e0d5 Fred Cooke: Remove LICENSE.txt file and update the markdown file with a whole section on intent and exceptions.
(14:05:58) DeuceEFI-git: (notice) Jaguar/dev 6ca46ba Andy Goss: Added LEDs and resistors to ignitor outputs.
(14:05:58) DeuceEFI-git: (notice) Jaguar/dev 4a074fa Andy Goss: Changed fuel pump LSD out for high side driver, removed Fan and LSD1 individual low side drivers for a pair of dual MOSFET low side drivers.
(04:45:13) DeuceEFI-git: (notice) Jaguar/dev 208ef71 Andy Goss: Changed revision to 0.7-alpha and git hash to xxxxxxxxxx to show that this is in progress.
(09:30:16) DeuceEFI-git: (notice) Jaguar/dev 5bd9888 Andy Goss: Changed Spare ADC and IAT cpu pin capacitor from 1uF to 0.22uF. Also changed pcb revision to 0.7-alpha.
Those are from a several-day period. Progress is being made. I need to review those recent changes today. Check the dev branch TODO list for info on what's left, if anything.
I just got myself caught up on this thread (I did skip quite a bit because of time restraints). I would like to do testing. I have a Ford V8 302 with ITB induction on the stand ready for a Factory Five Roadster project beginning Mid April.
What steps would you like me to take to get started?
What is the best way for me to get the hardware in my hands?
I would be very interested in building the board too, so no need to feel obligated to supply finished hardware.
rickjatrbdashcomdotcom
at = @
dash = -
dot = .
Email me if needed.
Thanks,
Rick
at = @
dash = -
dot = .
Email me if needed.
Thanks,
Rick
Rick, I would strongly suggest getting the surface mount option when ordering if it will be available again. Andy has an oven to flow the SMT chips on properly, soldering iron is not the way to do these especially the max chip and the usb port. The through hole stuff is cake and allows you to customize board to ignition option. See Feeds minimal build post to see what can be done on budget ie. you don't need 8 injector drivers for a 2 channel bank or batch fire. There may be EDIS support in the future but not at this time.
Rick, make us a project thread about your car. I've been following Factory Five since almost their beginning and have visited the factory. I had a plan to build one for a very long time. I'd love to see what you're doing with yours.
