Good catch on that one, I will save the two I already have for another projectTonyS wrote:Only other thing that I can see right now, is that the crystal is spec'd for 70C max. and I am not sure if you have a higher operating temperature environment spec as a target (85C?).
  I have added a crystal from the same manufacturer (same datasheet and load capacitors) with a -40C to 85C temperature range rather than the -10C to 70C temperature range of the one I originally chose to the BOM.
I also added a variety of crystal load capacitors so that I can test to see which one actually works.
Almost missed this one while I was preparing the above reply...TonyS wrote:One more little thing -
The schematic shows 22uF caps on the outputs of the regulator and the BOM calls out 47uF.
 The BOM has the correct value I wish to use, I have updated my schematics on my PC and have committed/pushed the KiCAD files just now and will have the schematic PDF up in a few minutes...
Thanks for all the input!
