Hentai's Project Ditch-MS2
Re: Hentai's Project Ditch-MS2
Flashing light = CEL (Check Engine Light). What it's trying to say is "go outside and check your engine, someone has modified it in a terrible way.".
More seriously, though, connect with some serial terminal application: The flashing proves that the firmware is dumping out massive amounts of data constantly, so you'll see that if you connect with a serial terminal app.
viewtopic.php?f=41&t=1623&p=24821#p24821
Try that.
Try that.
Ok I did that and got this.
that log is 115k, 8, none parity 1 stop bit, non hand shasking
[The extension log has been deactivated and can no longer be displayed.]
odd parity is correct, not none.Hentai wrote:that log is 115k, 8, none parity 1 stop bit, non hand shasking
BUT, if it's streaming data at you, then the ECU is healthy and your issue is with EMStudio, or your usage.
Log needs to be a binary file. If you can save it as a binary file with the correct settings and .bin extension, try opening in OLV.
Just rename olv.log to olv.bin
malcom2073
Congrats!
- masterkorp
Congrats!
So pin one was the issue, huh? Progress!
Yeah just pin, used a dab of solder to reconnect pin 1.
