Jaguar Build Chat Thread - For The Casual Builder
em_knaps
Re: Jaguar Build Chat Thread - For The Casual Builder
Post by em_knaps »
ya sure
http://vwparts.aircooled.net/v/vspfiles ... 852M-2.jpg
they had a batch of faulty ones so there are a few cases floating around.
regs will be heat sinking to the end plate.
I had to file the edges of the board at an angle.
I think I'll put some sort of bulk head plug at one end for connection
HD13
Post by HD13 »
Use a hacksaw to make those profiles deeper ?
To get a more earthly snug fit.
em_knaps
Post by em_knaps »
na the board is just too wide to fit even if I deepen the slots.
you don't need to take much off the board at all to get it to fit at an angle. but the regs do end up on a funny angle.
I may change the way they are heat sinked to the case. perhaps a tight fitting piece of ali that sits in a slot.
walinsky
Post by walinsky »
What wire gauge/diameter(s) are you all using on the Jaguar?
This question pops up from time to time, and I never remember the answer. Three numbers come to mind 20 22 24, I think 20 is too big, 22 is tight, and 24 is loose? Something like that. Hopefully DeuceEFI will drop in and give us his 2c at some point soon. I should probably measure a few things and sticky the info :-)
