Peugeot 2.0 Turbo on CardS12
Matthijs
Re: Peugeot 2.0 Turbo on CardS12
Post by Matthijs »
Small sign of live, ping ping. =]
Busy as *** getting this car finished to get on the road. I'm so keen on getting this engine running on FreeEMS that I have to finish some other things first like getting this car legal.
Currently I am working 5 evenings per week on this car to button some things up, some buttons larger than others ;)
This is the car starting again after 1,5 year since the start of the project:
http://www.youtube.com/watch?v=WAMVVYB50qc&hd=1
(some good headphones or speakers required)
Fred, tnx for your input. I recently received my lm2940('s) so I can start to build something. Most of the other major parts have arrived so things could go fast once I start on the board. Still struggling to get the S19 serial monitor on the S19x through Codewarrior, lol... off to a good start ;)
USBDM + Linux + client = easy.
Matthijs
Post by Matthijs »
My hacking efforts so far: LM2940 bottom left, TPS and EGO inputs above and the BRV to the left of it.
Now I'm deciding on which resistor values to use with the standard peugeot sensors (most likely bosch stuff) and a MAP sensor
Matthijs
Post by Matthijs »
Some progress, added more input filters and Fuel Pomp relay output and the 4 injector output:
Matthijs
Post by Matthijs »
Only got the MAP and VR input left, but I'm going to test all the inputs/outputs first now.
After the testing I'm going to connect all the wires to the Motronic 55 pin connector to regain some structure in the view...
HD13
Post by HD13 »
Matthijs,
You did use coloured wires !
Aint that enough structure :lol2: ?
Matthijs
Post by Matthijs »
http://www.youtube.com/watch?v=BE85-lzEOfE&hd=1
Benchtest is running :)
Only need to build the VR input and MAP now hardware wise and then put it all in a decent casing :)
DreadyD
Post by DreadyD »
That's a sweet sound, good job and gave me inspiration to give it a try myself. Great color coding as well.
Matthijs
Post by Matthijs »
VR sensor tested in circuit:
http://www.youtube.com/watch?v=bNTKdQvk66E&hd=1
Tested all outputs again after some wire adjustments:
http://www.youtube.com/watch?v=xLnZ9YJRW0E&hd=1
Only the MAP is left now :)
Static overview:
Very neat! :-)
