Turbo'd Slaters TA build.
Posted: Thu Sep 29, 2011 11:48 am
Greeting's fellow petrogeeks,
Under orders from fearless Fred I created this thread for the TA/vero build i intend to run my turbo'd EFI'd Citroen GS with
EDIT: Comments here: viewtopic.php?f=62&t=1337
these are images of the car (above), and the beginnings of the TA/vero ECU (below)
Indeed Fred commented that it was a long motherf****r, I could not help but blush.
the Engine is a 1299cc engine from a later model Citroen GSA with a toyota trans speed sensor replacing the original diagnostic TDC sensor and the flywheel machined with 10 more grooves in it to create a 12-1 type signal.
injectors are 300cc from a some sort of Ford mounted in the original manifold runners.
Igniton is achieved with a subrau wasted spark coil and igniter.
Up till now the car has run reliably 1st on a MS1 V3 board then downgraded to a MS1 V2.2 when I stole the V3 for my supra.
The current engine is junk as it suffers from much blow by after a heroic boost wind of 18PSI. It still runs fine but breathes heavily on anything higher than 5psi boost so it is a perfect candidate as a test mule and its simple set up makes for easy implementation of a fledgling EMS.
I must thank those involved in procuring the TA card for me and to Fred for having confidence that id actually do something with it.
let the ecu construction begin!!
Daniel.
Daniel.
